87 Wanna Be K30
headers...
i have a set of headers for an 88-94 chevy non vortec blah blah 350...yea. they are the shorty headers made by pace setter. do you think they will fit on my 87? i have a feeling they wont due to the body style change. i wish the edelbrock shortys werent so expensive. any help would be awesome.
A buddie of mine is running them on his 84 they are 88 up shorty's the should fit yours also. There should be a hole for a O2 sensor also.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
87 Wanna Be K30
so with the stock Y-Pipe it should work? do you think you could find out if he changed the y-pipe for me maybe? that would be awesome! thanks.
-Scott |
Right on the line, baby!
Find the part number on the manufacturer's web site and check the application from that. Or just call 'em & ask.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
No No
Ive been in contact with pacesetter a few times they typically dont know if something will fit somthing that isnt aplication spec.
The headers will fit with no problem the y pipe may not unless your current pipe routing is similiar.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
He will be running dual's. Not sure if the Y pipe would work.
Why get headers if you keeping the same restrictive exhaust tubes ?
