03-04-2004, 04:16 PM | #1 |
Struggling Artist
Lifts
Question; how much lift is too much in you're opinion?
69 1/2 ton lwb lowrider 90 C-1500 2wd 08 2500 HD 4WD 94 Grand Cherokee 49 Cadillac sedan |
03-04-2004, 04:31 PM | #2 |
If you are not doing it for offroad reasons, it's all opinion. I personally think that a nicely done, only nice day cruiser, should have as much lift as can be afforded, and then some.
I have always loved the philosophy of Go Big or Go Home! When it comes to usability for offroad, it then depends on what you are doing: mud, deep water crossings, rocks, trails, etc. Everyone has a personal opinion but I like to strike awe into peoples minds so they think, wow, that thing is huge. Kinda like how Bigfoot started. If it's 2 wheel drive, put it on the ground, if it's 4 wheel drive, put it in the sky.
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
03-04-2004, 05:13 PM | #3 |
I agree with GreenMystChevy. I lifted mine as high as i could afford and then borrowed money to go a little higher.
03-04-2004, 07:33 PM | #4 |
Too many is never enough!
IMO
Since this is all opinion, I'll chime in....4 to 6 inches max with up to 35s for a driver with decent off road capability. 2 to 4 inches and a sawzall if you want a rockcrawler and then pop on some 40s! Any taller on the street and you'd be compensating for something else.
Seriously, just stay practical! Decide what you'll use it for most and gear your lift and tires to those needs. You don't want to be running a 8" lift and 38s if you're driving to work everyday. Don't forget the money you'll have to put into gears with bigger tires also!
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
03-04-2004, 09:36 PM | #5 |
Is that a Chevy 69...?
main thing
It all depends if you want to park in a garage, a parking ramp, or go under over passes on the freeway! And if you can drive, so you don't roll it over, otherwise the sky is the limit. Just don't jacker up and leave dinky tires on (looks dumb)
Ahhhh, the wonderful sound of a rumbling V8. |
03-04-2004, 10:56 PM | #6 |
PROJECT 7DEUCE
6-8 would be my choice for a daily driver with 35 or 38 tall tire's..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-04-2004, 11:25 PM | #7 | |
Bloo
personally for a driver or never see anything but black top, 2 inch MAX, maybe a leveler kit for the front, but if your gonna use it, build it for what your doing... i cant stand lifted 4x4s if they dont see mud, thats what that front axle was put there for IMO
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
03-16-2004, 10:34 PM | #8 |
leaf spring easy lifts
How do you lift yours?
Is there an easy trick thats cheap for the leafs? I know I'd buy new proper length shocks, I want to go whatever gets me to 33" tires or so, about 4" lift then? Should I do a body lift, what combo do you use? Thanks
03-16-2004, 11:31 PM | #9 |
http://rough.roughcountry.com/Lift%2...re%20Chart.htm
Try this chart. It should help you out. You have the right idea though, choose the tire size you want and then lift the truck to accomidate them. I am running 35x12.5's with 4'' susp lift and 3'' body lift and have enough room to clear 37's without any other modifications. If you want to go cheap and do not plan on doing a lot of offroading, you could use blocks to lift it. They sell them at most parts houses. I do not recomend this if it is going to be used off road often. I would buy a full susp kit with new springs from one of the big manufactures like Superlift or Skyjacker There are a few others out there, just do some shopping and ask people what they have and how they like it. I hope I helped? Mario
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
03-17-2004, 12:41 AM | #10 |
i think 8 inches is about as far as it can go and still look good. when your truck starts to go into the realm of not even having tires in the wheelwells cuz you are lifted so high and the tires are so big, I don't think it looks too good. However, I know you need this kind of clearance for some kinds of offroading. This may make me sound like a pavement pounder, but i like a good compromise of looks & performance. I want to eventually get 6" all spring lift and use 35's. Heck, when my truck ran, I would still wheel it where I could with open diffs, stock ride height, and 32" tires.
As far as lifting trucks just for show, I don't know if I necessarily agree with that. However, lifting 2wd trucks is (IMO) one of the dumbest things someone can do.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-17-2004, 01:24 AM | #11 |
lift
i put a 4" rancho lift, big o big foot at's 33" looks real tough but sure wish i would have spent the money and did a 6" lift and 35" tires, i think this summer i will take my front springs off and take the press to them and make 5 or 6" of lift leave the 4" blocks on the rear and have the rear springs arched 2", already have done the longer braided brake lines to accomidate 6" lift. done the raised steering arm, anyways my opinion the 67 to 72 look bad ass with 4" or 6" i like 6, dont forget to get some nerf bars so you can get in without a ladder. hope this helped
03-17-2004, 01:41 PM | #12 |
yep
helped alot, when would I need to adjust steering? Certain height? I think I will flip the spring perches possibly. Would I need to do the steering? Is it tough?
03-17-2004, 01:52 PM | #13 |
so..
How big will fit without a lift?
03-17-2004, 03:45 PM | #14 |
user # 2756
I had 325/60R15s on 15x10s that rubbed a little on my 70. I installed a 2" tuff country HD springs up front and a 2" block w/ add-a-leaf in the rear. I actually ended up with about 3" in front. I now have 33s on 15x10s and no clerance issues.
Will be installing a 4" rough country lift on the 71 here soon.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-17-2004, 03:46 PM | #15 |
user # 2756
Don't need to flip the spring perches they are on top now.
03-17-2004, 03:50 PM | #16 |
i like the 2" lift with 33s on my '85...it can still fit in parking garages and under low hanging branches but has enough ground clearance to clear hurdles.
-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
03-17-2004, 06:06 PM | #17 |
I HAVE A SUPERLIFT 6" LIFT WITH 35" TIRES..IM VERY HAPPY. VERY SMOOTH RIDE. HERES SOME PICS..
http://67-72chevytrucks.com/vboard/s...hlight=RICHARD |
03-17-2004, 09:48 PM | #18 |
other things
how about the steering thing? is there anything else that needs adjusting?
03-17-2004, 10:54 PM | #19 |
PROJECT 7DEUCE
Hey truck's you may wanna pm pont he could help ya out with some great info....
03-18-2004, 01:23 PM | #20 |
thanks will do
thanks again
03-18-2004, 01:57 PM | #21 |
lifts
I lifted mine 10 1/2" put 40" tires on it and take it everywhere. Drive it daily. Put a od trans in it. has lots of bottom end and good freeway rpms too. around town i get 10 mpg, hwy 16-18 mpg.
Dwayne you can check it out @ www.geocities.com/scbeoffroadunlimited
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration 67' Chevy, What to do??? And Bad Ass American Bulldogs! |
03-20-2004, 02:13 AM | #22 |
City's Articulation Ramp
I started with an 83 3/4 ton with 4" lift and 33", then went to a 92 K1500 with 6" lift and 35". Now they both seem real tiny, then were big for a while. I want to go stupid big now. 10-5" lift and 44". Probaly 10" with a little fender hacking, big but with a low center of gravity. Just remember wide tires; not only do narrow tires look funny, but they are un-safe. You need a good base. As modifications, remember you might have to hack fenders, over 8" of lift need crossover steering, and I would say a 33" tires on solid axle and 35" tires on IFS need steering stab. or else you will be wondering all over the road. Just my 2 cents!
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy 00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver 06 Harley Sporster 883 low 19?? Zamboni, Really I own a Zamboni! "If your gonna be stupid, then you better be tough." |
03-20-2004, 03:34 AM | #23 |
world class smart ass!
not mine, no info, just posting pic that I like..
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ____________________________ |
