12-17-2009, 12:38 AM | #1 |
Is an S10 rear the same as ours?
I have a 1/2 ton 64 GMC, and my friend recently swapped out the ring and pinion on his 1999 S10, I have 3.73 and his is a 3.08. I can have it for free, but would it work in my 64?
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-17-2009, 12:40 AM | #2 |
60-66 Nut
Re: Is an S10 rear the same as ours?
No, completely different rear end. Is your rear suspension leaf spring or coils?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-17-2009 at 12:41 AM. |
12-17-2009, 01:02 AM | #3 |
It's leaf spring rear.
12-17-2009, 01:26 AM | #4 |
60-66 Nut
Then you most likely have a Dana 44 differential. Just so you know what you have when you look for gears. Does it look like this? This is a Dana 60 cover. The 44 looks the same just smaller.
12-17-2009, 10:56 AM | #5 |
Yeah that's what it looks like, 10 bolt and all. Thanks for the clarification.
