Old 08-31-2012, 11:56 AM   #1
mr.wilson
Auillary tank capacity
I found this picture on here and I have the same tank. Anyone know the capacity?
Wilson
1972 Cheyenne LWB, 350ci TH-350.
Restoration in progress.
mr.wilson is offline   Reply With Quote
Old 08-31-2012, 02:17 PM   #2
SS Tim
SS Tim's Avatar
Re: Auillary tank capacity
Your tank.is an aftermarket. There were a number of companies that made these in a number of styles. Both singles (like the factory NL2) or in pairs. The end fills were the cleanest installation without hacking holes in the bedsides. Most ran between 17 and 19 gallons each.
SS Tim is offline   Reply With Quote
Old 08-31-2012, 02:23 PM   #3
mr.wilson
Thanks Tim, much appreciated. Any idea who the manufacturers were and if there are still in business? Want info on sending units and mounting the tank. Plan to take a look at it this weekend.
Wilson
Old 08-31-2012, 03:04 PM   #4
SS Tim
SS Tim's Avatar
Doubt that any of the manufacturers are still around. Without a sticker or stamping the maufacturer will remain unknown. The sending unit is likely fairly common. Pull it out and clean it up. Might be repairable or at least identifiable. Most of the tanks were suspended by through bolts and located with a body flange or tabs. The factory used a similar system that was much more refined than most of the aftermarkets long bolts with nuts and washers. Here are a couple of pictures to help.
