11-08-2009, 01:40 AM | #1 |
Best rear drop?
Working on my first '72 project and wanting to know which rear drop would be best for ride quality. 6" drop coils or 2" blocks and 4" coils?
11-08-2009, 02:12 AM | #2 |
Re: Best rear drop?
First off, welcome. I don't believe there is a difference in ride between the two, I've had a truck dropped 4'' in the rear and one dropped 6'' and didn't notice a difference. I'd go for the 6'' springs since the springs are the same price and then you don't need to spend money on the blocks.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
11-08-2009, 02:23 AM | #3 |
Re: Best rear drop?
11-08-2009, 08:20 AM | #4 |
Re: Best rear drop?
welcome and for sure go with 6 inch rear springs forget about the blocks....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-08-2009, 09:11 AM | #5 |
its all about the +6 inches
Re: Best rear drop?
you'll want to plan on a c notch in there too. the axle will probably slam into the frame a lot
11-08-2009, 10:52 AM | #6 |
Re: Best rear drop?
dont forget shock relocators and adjustable panhard//i like to use new trailing arm bushuings too
11-09-2009, 02:37 PM | #7 |
Re: Best rear drop?
I was wondering about the c notch and forgot to ask earlier. Is the adjustable panhard a must have? I've got it completely apart and was gonna do the bushings, just trying to get a complete list together so I know what to order.
11-09-2009, 02:41 PM | #8 |
Re: Best rear drop?
a 4" drop would be better with an adjustable panhard bar, drop shocks and shock relocators...
So a 6" drop would need these for sure... |
11-09-2009, 03:07 PM | #9 |
vw guy & now c-10 guy
Re: Best rear drop?
Im doing a 7" drop in the rear with 5" springs and 2" blocks. Adjustable panhard bar, drop shocks, shock relocater kit, c-notches, and drop center crossmember-- BUT I havent started on the rear yet- just got the front end together yesterday (5.5" drop) 3" springs and 2.5" drop spindles. I bought my truck somewhere around Hardinsburg btw lol Good to see another KY guy on here! Good luck man!
11-09-2009, 03:38 PM | #10 |
Tot Roddin'
Re: Best rear drop?
As with many posted above... just run the 6" spring. It's what I installed on my '69 (w/o a notch) and I have yet to bottom out.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-09-2009, 05:47 PM | #11 |
Watch out for your cornhole !
Re: Best rear drop?
I've run 6 inch springs on a good number of trucks with no c notch and never had a bottoming issue either.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-09-2009 at 05:47 PM. |
11-09-2009, 06:17 PM | #12 | ||
Re: Best rear drop?
I agree 100% as I also have six inch springs and have never bottomed out...of course the streets aroubd here are relatively perfect....
11-09-2009, 07:28 PM | #13 |
Re: Best rear drop?
I appreciate all the info. Like I said first build so I'll probably have a million more questions. Soon as I figure out how I'll get a build thread started so you can see what I'm working with. Haven't figured out the pic upload yet
11-09-2009, 09:41 PM | #14 | |
Old Skool Club
Re: Best rear drop?
This is what I have done, but I'd really like to drop it another inch...or two. Geeze, it never ends.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-10-2009, 09:02 AM | #15 |
Tot Roddin'
Re: Best rear drop?
Once you start you'll never be low enough.
11-10-2009, 09:16 AM | #16 |
Re: Best rear drop?
With a 6" drop, i would get ECE's Super Track Bar kit. It relocates the panhard bar to get better articulation and proper geometry. I used one with with my 5" rear drop and it's a major ride improvement over the adjustable panhard bar with 4" drop.
www.photobucket.com is your friend for uploading pics. Download them there, then just copy and paste the [IMG] code. Also, WELCOME to the the board from East TN!
11-10-2009, 09:52 AM | #17 |
Re: Best rear drop?
11-10-2009, 05:50 PM | #18 |
Re: Best rear drop?
my bad. I forget that a burb is a tad heavier in the back. I put 4 inch drop springs, and had an inch between the frame and axle. Sitting on the tailgate (I'm only 205 - 210 pounds) would slam the axle into the frame.
11-10-2009, 07:24 PM | #19 | |
Re: Best rear drop?
11-11-2009, 08:50 PM | #20 |
the boat guy
Re: Best rear drop?
6" springs, great when the truck is empty. i do a little towing and hauling id like to pick up some air shocks or bag it. i ride the crap out of the umpstops when the truck is loaded, it doesnt ride horrible but id like the unloaded ride when im towing.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
11-12-2009, 09:03 AM | #21 |
Re: Best rear drop?
brad man, nice truck and nice boat!!
