Old 09-01-2003, 10:05 AM   #1
Beowolf
1/2 ton into 3/4 ton?
We have a71 4x4 half ton that we've driven since '85. It is time for a rebuild, and we've just begun the tear down. We will be replacing the springs, ppossibly putting a mild (2 1/2") lift on it. Does anyone know if 3/4 ton springs will bolt in? I'd like to increase the carrying capacity if possible. Thanks.
Beowolf is offline   Reply With Quote
Old 09-02-2003, 06:42 AM   #2
JimKshortstep4x4
Smile
The 3/4 ton springs will interchange with the 1/2 ton 4x4's.
Jim
Old 09-03-2003, 07:52 PM   #3
Beowolf
Thanks for the reply. I'll give it a shot.
72 Blazer CST
71 1/2 Ton 4x4
Old 09-04-2003, 02:48 AM   #4
mindhive
Take note that the springs are not the only thing that have bearing on your trucks load capacity. Heavier trucks also have full floating axles, bigger brakes and I believe thicker frame matrial to handle the extra load safely. Hate to see you destroy your rear diff, break an axle and have your rear wheel pass you going down the highway or not be able to stop as quick as you thought you could??
OK, I'll shut up now...
mindhive is offline   Reply With Quote
Old 09-07-2003, 09:59 AM   #5
bigger=better
bigger=better's Avatar
I want to install the front and rear diffs. (along with auto trans. and TC) from a '73 3/4 ton 4x4 donor pickup into my '68 1/2 ton 4x4 suburban. It currently has a 3 on the tree and 307(to be replaced with markVI 454). Can anyone forsee any problems?
'68 GMC Sub 4X4 new project
'69 Pontiac GTO 20 year project
Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from.
bigger=better is offline   Reply With Quote
