Old 06-08-2011, 09:31 PM   #1
biggsteve97
charging issue/slight display pulsing/flickering
The volt gauge in my 2003 Tahoe sometimes drops from just above 14 volts down to roughly 11-12 volts and also has a slight flicker/pulsing to the PRNDL, info center, and Climate control displays. Ironically the radio and dash light are night affected. I replaced the alternator last September and installed a new instrument cluster 2 months ago. I honestly do not remember when this started but I do know the pulsing was there before I replaced the cluster. I read a tsb once on a feedback issue from the alternator harness plug that might cause transmission shifting issues and was wondering if that might have something to do with it. I do occasionally have a 1-2 shift issue, when it shifts it hangs 1-2 seconds between releasing first and engaging second. At one point there was also a loud "clack" sound from 1-2 at wot shifts. I believe that to be a worn or broken 1-2 accumulator piston and that should also explain the shifting issue. Any ideas on the pulsing issue.
biggsteve97 is offline   Reply With Quote
Old 06-11-2011, 11:17 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: charging issue/slight display pulsing/flickering
Anybody?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-16-2011, 01:16 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
My 01 tahoe does the same thing sometimes when I let off the gas it will drop below normal idle RPM and the lights will dim for just a second then it will kick back up and act normal. Hope someone has ideas....
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
