Starter - pmgr
Just recently picked up a 1970 gmc long bed truck yesterday. Previous owner did not have a ton of information on it but a prior owner to him swapped in what appears to be a 1980s truck 207 block that appears to be rebuilt or at least a lower miles as it runs very smooth with a edelbrock eps intake, edelbrock carb, and headers.
I am doing the general maintenance plugs, wires, cap, rotor, and oil change. While there wanted to change the starter motor over to a pmrg since I want to run new positive cables. I am newer to Chevy engines as I have owned more fords. Just checking I get the right starter. Would I lookup a 1996 Silverado 5.7 auto and use it? Was looking at this https://www.oreillyauto.com/detail/c...=starter&pos=0 |
Re: Starter - pmgr
Check out DB Electrical. Great folks and great customer service. I have bought numerous products from them and always have been impressed with their quality.
71 C-20 07 Magnum RT AWD |
At the body shop.
Re: Starter - pmgr
That starter will need 11610633 starter bolt. Or an equivalent.
I use the 337-1022 for a pn to cross over for the starter. Have 4 on our fleet of old trucks.
" That didnt make it any newer " " Dont antique the equipment " |
#4 | |
Re: Starter - pmgr
Any idea on the db electrical starter part number? |
Re: Starter - pmgr
OP, I got my PMGR starter from rockauto for around $70
Remy Here is the X reference chart for part #'s. Mine came with new knurled bolts |
At the body shop.
Re: Starter - pmgr
Re: Starter - pmgr
If the present starter is working w/o issue why change? Change for the sake of change is one of the biggest reasons for posts about how do I fix X on vehicle forums.
Re: Starter - pmgr
I know nothing about the truck. Trying to do all the maintenance and odds and ends that might cause a break down.
![]() Join Date: Dec 2009
Re: Starter - pmgr
DB Electrical is a Great company to do business with.
Give them a call and they will get you what you want.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jan 2001
Re: Starter - pmgr
They're the only ones I use for starters and alternators.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Starter - pmgr
Thanks. I did some googling and it seems a 96 tahoe is a good lookup vehicle. Found a gm number for one. Sent db electrical a message to confirm if that right and what one from them I should use.
Re: Starter - pmgr
They are only 3/4 hours drive from my house.
I would like to visit sometime. ![]()
#13 |
Re: Starter - pmgr
I’ve had two DB starters fail on me . One in my Chevelle and the other in the 72 . Not bashing them but it turned me away from them . Been using Powermasters with out a clitch . Have them in three cars for a while now . Just my experience YMMV
#14 | |
Re: Starter - pmgr
When looking up a 96 tahoe starter found a wai 6449n (i was told wai is napa) and is on amazon. Might pick one up for my 55. Havent put the motor in the car yet so no rush. |
