Old 01-02-2010, 10:08 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Question 20" dodge spares on my chevy?? Help!!
lik it says I saw a pic of one of our trucks and like the look so Iwas thinking about it..I mean the spares must be prettty easy to find...But I need to know what I need for an adaptor to make it woark and where to get them??cost?? and wheel clearance since I'm bagged...
also can you get the wheel adaptors for 6 lug or 5?? Might be away to get out of an axle swap??
Thanx
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-02-2010, 10:33 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 20" dodge spares on my chevy?? Help!!
Looks like the Dodge wheels are 5 on 5.5 bolt pattern, Chevy is 5 on 5. Adapters are available but not cheap.
5 bolt
http://villagevoice.backpage.com/Aut...d?oid=11857855
6 bolt
http://www.ezaccessory.com/ProductDe...-5550&click=35
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-02-2010, 10:42 PM   #3
Hottrucks
Hottrucks's Avatar
ouch $130 a pair.......
spares must be $200 for 4
under $500 for a set of new 20's is pretty cheap if they fit
Old 01-02-2010, 11:39 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
check this thread....
http://67-72chevytrucks.com/vboard/s...e+spare&page=2
C10addict was going to run them on his 67 but didn't because they weren't going to fit well with his drop and the stepside fenders w/out modification....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-03-2010, 01:08 AM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Hmmm...anybody runnin em yet...something Id like to do cept tires are so expensive for the things lol.
John
1999 Toyota Tacoma 4x4
Old 01-03-2010, 04:27 AM   #6
OARNGESI
OARNGESI's Avatar
Are you still 6lug have you thought about the 17 fjrims
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-03-2010, 05:34 AM   #7
Hottrucks
Hottrucks's Avatar
Do they Fit...( should??)..I'll have to see what they look like
yes I'm still 6 lug
Old 01-03-2010, 05:56 AM   #8
OARNGESI
OARNGESI's Avatar
HERE YOU GO http://67-72chevytrucks.com/vboard/s...d.php?t=368720
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 01-03-2010, 03:51 PM   #9
Hottrucks
Hottrucks's Avatar
thanx that was acually the truck I was thinking of...my bad??...guess Ill start looking around for a set
Jeff
Old 01-03-2010, 04:36 PM   #10
tcb-1
Nothing to see here.....
tcb-1's Avatar
Jeff, that's my beater. they are 6 x 5.5 lug steelies from the new FJ Cruisers and they will bolt right up to your rig. I had no issues with the disc brake or drum brake interference and, since your truck is hammered, you can tuck these with or without spacers. use standard acorn nuts, and your good.
they are 17" x 7.5" with an approx. 5.25" backspace.
I got mine an Ebay, but you should try salvage yards AND Toyota dealerships. some people will order an FJ "plainjane", but have the dealership install TRD or custom rims and tires. the dealership then either shelves them or sell them.
good luck!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-03-2010, 05:20 PM   #11
tcb-1
tcb-1's Avatar
here's a closer pic for you, Jeff......
Doug
Old 01-03-2010, 10:20 PM   #12
Hottrucks
Hottrucks's Avatar
Thanx Doug...
what is the stock size tire on these?? and what color did they come?? I'm old school so black works perfect, I think I saw a set that where OEM and where so I'm half way done.....
Of course I want as wide a sneaker in back I can get.....what would you recommend without the spacers..or what do you have then I can feed that Info into My tire calculator to get the righ height (29.5") for the front to clear my inner fenders...in back I may go for a bit of rake and a taller side wall
I think I will need to hunt for a trim ring for them though?? kinda like the look I have just want to hide a little more tire
thanx great NEW idea
one more quick ?? What is your set up in the front?? I have cupped LCA and bags with a 2.5" C notch in the rear.....Just woundering if I will sit the same as you??
Old 01-03-2010, 10:23 PM   #13
63chevyll
gets board easy.......
63chevyll's Avatar
thats a pretty good idea, I like th FJ wheels
63chevyll is offline   Reply With Quote
Old 01-03-2010, 10:52 PM   #14
tcb-1
tcb-1's Avatar
Jeff,
actually, these rims were originally black.... and a nice coat of black at that. I just scuffed them, hit them with a PPG primer, and then a single stage clear coat gray.
as far as wide goes, I'd have to defer to more of a tire expert. however my guess would be that you could probably go to 10.5" wide? I know I ran 11.5" wide tires on a set of 8" rims years ago.
the tire sizes are 225/55/17. want to be able to tuck them after I get the air ride installed......
and, as far as my drop, here it is:
front:
McGaughys 2.5" drop spindles
Suicidedoors drop in cups (shaved 5/8") with stock lower control arms
Dominator D2600 bags
Shocks (who knows)
rear:
CPP bolt in c-notch
3" custom made drop blocks
ECE adjustable panhard bar
ECE shock relocators
Shock (who knows)
the pic above is of the tire just in contact with the inner fender. with cupped lower control arms like you have, you should be lower than I.
Doug
Old 01-04-2010, 02:02 AM   #15
BarryB
BarryB's Avatar
YOu should hit Big al 71 up, since he runs a toyota dealership. I'm sure he can hook you up with a set of FJ wheels
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-04-2010, 07:38 AM   #16
Hottrucks
Hottrucks's Avatar
thanx again doug,
I think we maybe even due to your drop spindles...I will say My inners are gone with my 235/75 on...but I can lay the LCA on my x memeber....spindes would put me into the other issues...so this will give me the tucked look with out having to other stuff
I have a tire cal I'll post when I get home again ( f'n snow) then you can play with the # if you want
