Remove front leaf? Or not?
I am building a 48 Chevy 3100. I am doing a static lowering job. I have Posey lowering leave springs on the front. There are two of them. Can I safely remove one just leaving one to get a little lower stance? I have the room or Clarence, I'm just wondering if one single leaf would be strong enough.
Thank you in advance for any advice or comments. |
Re: Remove front leaf? Or not?
I wouldn't do that. i'd look into a drop axle. if there is not much deniro in your budget you look into putting the springs under the axle.
polishing a turd
We just pulled a couple out of the factory spring pack. I wouldn't run just one unless it was designed as a mono leaf though
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
