04-15-2009, 09:27 PM | #1 |
Front End Alignment Issue
I really don't know if I am asking the right question......I need or would like for my '72 pickup to corner real well without too much tire wear. I am not going to Auto X it but I would like to get the most out of it. I have 17 X 8's up front with Nittos and 17 X 10's in the rear. Sway bars front & rear ,Bilstine shocks all around. The front end shop tells me to ask for specs. from you folks. Any input?
04-15-2009, 09:32 PM | #2 |
Nothing to see here.....
Re: Front End Alignment Issue
is you truck dropped. if so, how? spindles, bags, springs?
off the subject, but what type of rear sway bar do you have???
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 04-15-2009 at 09:32 PM. |
04-15-2009, 09:34 PM | #3 |
the whole spec sheet for the front end alignment is in the factory service manuals(available from most board vendors) i'd go to a different shop ,they should have the spec if they're any good
is the truck lowered if so how? lowering springs and cut springs alot of times dont align well
04-15-2009, 10:11 PM | #4 |
I picked up a sway bar kit from CPP Trucks. It came with great instructions and all parts needed. The other question ....I am using stock 6 cyl. springs all around. I have a BBC in it so it sits lower but still has a good "Stance" for me. I am not looking for stock specs. but more along a performance set up...maybe for the lack of a better work you could say a Auto X set up but not too much...Is that a good enough answer? I really don't know how else to describe it. Any thoughts?
04-16-2009, 09:13 AM | #5 |
Restoration Virgin!
All I found was this thread...looks like it's for a SBC....maybe pm 'cparman with your question??
http://67-72chevytrucks.com/vboard/s...d.php?t=335150
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-16-2009, 02:47 PM | #6 |
If you want an alignment for better handling tell us how it handles now, be specfic i.e. does it under/oversteer near the limit? How flat does it corner (pics would help)? What Nittos do you have (the most improvement in handling to be had is from tiers)? What size front and rear bar do you have?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-16-2009, 04:16 PM | #7 |
I set my 70 at 1 1/2 degree pos caster. 1/4 degree negative camber & 1/8 in. toe-in. It has a CCP front sway bar kit & HD shocks. There is no sway bar in the rear & plain gas shocks. It drives beautiful. I like to leave my car at home & drive the pickup.
04-16-2009, 04:42 PM | #8 |
sharp as a marble
GCburbic, thanks !! Here is my 1/2 cent worth. A mopar guy I know said that is all a Chevy guys opinion is worth.
0 degrees camber as much positive caster as you can get 1/8 " toe in IF you could get the camber NO MORE that -1/2 degree, and then fiddle with the caster to get as much positive caster as possible. IMO any more negative camber and tire wear will become an issue.You want a bit more caster in the right front wheel than the left. 1/2 degree more in the right than the left. IE 2.0 positive left front 2.5 positive right front. Set the to to spec, which I think will be 1/8th in. You are going to need to find a shop with a car guy aligning your truck. Most of the tire stores are " toe and go" kind of places. My employees will tell you that I am a PIA, because I am too picky. In the real world of aligning your truck, you may already have a BUNCH of negative camber in your truck. soft springs, bbc etc. Really all you can do is to work with what you have. In the end you may have NO positive caster. Ask the shop to print out a BEFORE AND AFTER sheet of your alignment. If they say they cannot thank them and find another old fart like me in your hometown. HTH.. PM me if you have questions Last edited by cparman; 04-16-2009 at 04:44 PM. |
04-16-2009, 06:12 PM | #9 |
Boy tell me about it! It is hard as H--- to find a shop that gives a rip about doing anything "Out of spec." as they say. What they are telling me is that they know how to line up two bars with a third bar, but they don't know squat about what it is doing or why! Sorry about the *****ing but I am sure you all have come across this same issue. Well I work 2nd and I have to run but thanks for the input and I will be back on line later......
04-16-2009, 06:18 PM | #10 |
Mine is pretty low and I needed a different upper A-arm designed for lowered trucks to get the camber back in spec.... it also was designed for more castor. It rides really well now.
You may want a quick ratio steering box if you want more responsiveness (though it can be a little twitchy). |
04-16-2009, 07:37 PM | #11 |
sharp as a marble
There has got to be someone in the Spartanburg/Greenville area that will adjust to your specs. Just keep a diggin
