67-72 parts collector,…
![]() Join Date: Nov 2002
Thorbecke Bros. A-Arms for bags,...
Ok Guys,... I have an inside scoop on some NEW tubular control arms. These things are super beefy and work with air bags on stock crossmember applications. (EDIT: They will not work with the "newest" design Dropmember,... But will work with the Thorbecke Bros. Raised Crossmember)
These pics show upper and lower arms, shocks, and new shock re-locators for the upper mount. Pictured, is the swaybar from ART w/ their PosiLink swaybar end$. I'll let Jason from Thorbecke Bros. (*****************) update us with prices. Until now, ART made the ONLY quality tubular a-arm for the bag guys. (Don't ask me about CPP) Just giving you guys a look at a NICE alternative. Look at the size of that tubing!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-06-2008 at 10:00 AM. |
Tot Roddin'
Re: Thorbecke Bros. A-Arms for bags,...
It's pics like this that make me want to change the plan for my project....
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
looks like some nice stuff.
Can't wait for the price...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
The CPP upper arms on my blazer may soon be for sale. Since I'm bagging it now,... I may be purchasing a set.
I know their S10 version comes in a huge selection of powdercoating colors. I'll probably check into getting just black. Word has it, they are ready to start shipping these.
I'll let Jason confirm these prices:
*Upper and lower arms $899.99 (full set) *Upper shock mounts $69.99 (pair) *Monroe sensitrac shocks $80.00 (pair) Hey Jason,... give us the heads up on powdercoating,... I'm ready to get some. Hmmm,... maybe I want a silver set,...
Maybe,... I'll just get the shock mounts and shocks and run my stock arms,...
Upper bag plate and cup $59.00, Slam Specialties RE-7 $75.00 each, Shock mount $69.99, Front shocks, $80.00 Quick bag job. One stop shopping,... Decisions, decisions,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-05-2008 at 11:56 PM. |
i check ***************** all the time for these "new" parts like these arms and the raised crossmember. when will i see them on the site, or do i just need to start saving all call when im ready?
1987 Gmc sierra 1962 Apache 10 |
Best bet is to call them. I've known about these for a while now.
If you can find it cheaper, I can fix it! |
A guy with a truck
I wonder if they will let you order them empty, like they do with their S10 arms? Saves you about half the cost...
Edit: What keeps them from working with the DM?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 12-06-2008 at 02:53 PM. |
Here are a few images of the upper cross shaft. The lower cross shaft has the same features.
Here is the upper cross shaft after all machining has been done. Notice the zerk fittings on top and the small holes on the part where the bushing goes? That little hole is where the grease comes out to keep the bushings all lubed up. Just one of the nice features about these control arms. [IMG]http://www.*****************/jason/images/arms28.jpg[/IMG] On the end of the shaft we slot it for a stainless lock washer. This will prevent the washer from turning causing the end bolt to back out. [IMG]http://www.*****************/jason/images/arms29.jpg[/IMG] Here is a pic of the lock washer and bushing in place. [IMG]http://www.*****************/jason/images/arms30.jpg[/IMG] Another stainless washer goes on and the bolt is then installed with loc-tite to assure that nothing is coming loose. [IMG]http://www.*****************/jason/images/arms31.jpg[/IMG] |
![]() ![]() Last edited by dubdeuce80; 12-06-2008 at 04:05 PM. |
A guy with a truck
Can they be used w/ stock shafts like the S10 arms?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#13 | |
http://www.*****************/catalog/...t-control-arms |
#14 |
#15 |
beautiful work. Wish I had waited.
#16 | |
#17 |
One day...
Yeah those are cool.
#18 |
can you just use the upper arms with the factory lowers?
my truck is bagged already just need the clean look of tube uppers before the photoshoot.
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
#19 |
Nice design on the shafts.
#20 | |
Junior Member
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol ![]() |
#21 |
I think $900 is a good price even without the cross shaft. With it is just plain cheap.
#22 |
Keepin it old school
I will be getting some of these when $$ allows to use on my Thorbecke Bros. Raised Crossmember..... Awesome as always Jason
#23 |
very nice, you guys machine them in-house?
the cross-shafts I mean.....
![]() ![]() Last edited by joe231; 12-07-2008 at 12:26 AM. |
#24 |
#25 |
