04-16-2004, 10:26 PM | #1 |
Is a overload leaf an option on a coil rear end?
I got a frame from zoomy and it is a coil rear end. It does not have an overload leaf on it. My 72 Cheyenne super does. Was this an option?
Thanks Ron
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
04-16-2004, 10:39 PM | #2 |
Try spinnin 4 rear tars
Yes it was an option... don't know any details on it though...
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
04-16-2004, 10:57 PM | #3 |
Yes it was
My 70 3/4 ton custom camper is a coil with overloads and I believe it lists them on the glove box sheet.
Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 |
04-16-2004, 11:22 PM | #4 |
Next!
Option G60, Auxilary rear springs, C10, C20 models with coil spring rears. capacity 500lbs each.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
04-17-2004, 12:01 PM | #5 |
PROJECT 7DEUCE
Yep my 70 frame had it on the back I still have the plate's that bolt to the axle if anyone need's em..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
