Old 03-18-2013, 12:21 AM   #1
Davemotohead
Davemotohead's Avatar
My new 12,000lb winch set up!
Took a reciever hitch extension and welded a couple plates to it and mounted a winch to it,,installed a reciever on my car trailer and one under the front bumper of my truck,,so now can move the winch front to back on the truck and mount it on the trailer,When mounted in the rear of my truck can still install a drop hitch to pull a trailer,only problem is it weighs 118 lbs!
edited by staff
Davemotohead is offline   Reply With Quote
Old 03-18-2013, 12:24 AM   #2
70cst
70cst's Avatar
Re: My new 12,000lb winch set up!
That is a serious set up
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-18-2013, 12:29 AM   #3
car66
car66's Avatar
very nice setup, i have to same winch on my gooseneck and another one to go on my bumper pull trailer. that is a great winch for the money.
1995 Chevy 2500 4x4 diesel (daily driver)
1971 Chevy 2WD pulling truck "Whiplash"
"The Bandit" twin engine pulling tractor
"Hog Wild" 2wd econoline pulling truck
car66 is offline   Reply With Quote
Old 03-18-2013, 12:55 AM   #4
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Funny I did the same thing today.
Looks good,
You might want to consider cutting the mounting tray down however, doing so will knock several pounds off of it, every little bit helps when you are trying to lift it.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-18-2013, 01:22 AM   #5
Davemotohead
I did cut the mounting tray down,left enough to protect the winch motor,here are before and after shots.
edited by staff
Old 03-18-2013, 11:17 AM   #6
kamikazekyle05
kamikazekyle05's Avatar
Nice welds!
kamikazekyle05 is offline   Reply With Quote
