06-04-2009, 08:24 PM | #1 |
How about a 96 SWB on an AD series truck?
I have access to a 96 SWB but it's in a different state. I'm considering it for a 49 Chevy but since the two are 5 states apart I haven't done the measurements.
Anyone done or at least considered this? I tried a search but did not turn up any threads. |
06-04-2009, 08:30 PM | #2 |
Re: How about a 96 SWB on an AD series truck?
The wheelbase is not the same, also I think the frame rails will be to wide for the body to fit over, but you can raise the cab high enough to clear them unless you are wanting it low and mean. AD SWB is 117" and I cant remember exactly what those trucks are. It can be done though. Maybe someone else will have more information
06-04-2009, 10:05 PM | #3 |
you need to use a standard cab long bed. the wheelbases match up pretty close. it is a narrower frame and you will need spacers for the wheels to make them fit. there are plenty of s10 frame swaps on this forum look around and you will learn everything you need to know. i am currently starting my s10 frame swap so i still have a long way to go.
06-04-2009, 10:11 PM | #4 |
I may have misunderstood. I thought you were talking about a fullsize SWB swap. If it is a S10 SWB you just need to lengthen the middle of the frame to have a 117-118 wheel base. 117 is original and 118 will perfectly center the rear wheels. As for the swap look at my thread and many others on this sight
06-05-2009, 08:51 AM | #5 |
if you are talking about a regular can s10 short box then look up my build thread. you will neeb to lengthen th frame in the middle to make the box fit or just shorten the box to a five foot six inch box like i did.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
06-09-2009, 02:56 PM | #6 |
If you are talking about a full size frame, it is possible. My truck is a '49 GMC that was mounted on a shortbed '91 Z71 4x4 by the previous owner. He did a good job, but I don't know the details of what was changed. I do know he fabbed a radiator surround and new inner fenders to use the '91 radiator. It sits pretty high - it actually kind of looks like a short bed 3/4 ton.
06-09-2009, 03:45 PM | #7 |
Thanks for the replies, but I led some folks down the wrong path by not clearly stating my intentions.
I was referring to using the 49 frame/cab and a SWB from a 96 truck. Since I don't have access to the 49 (several states away) nor the bed 200 miles away (offered to me free to get it out of the way) I can't get measurements to determine feasibility. I thought perhaps some folks on this forum may have considered or accomplished such a swap. |
06-09-2009, 04:44 PM | #8 |
ok but is the 96 a fullsize truck or a s series truck that is the key here that we need to know to help you out. a 96 truck is kinda vague. if it is a full size truck then yes you can fit the cab an possibly the box too. if you are looking for wheel base measurements to figure out if it will work, then just ask. their will be a lot of fab work to make it fit right because a 49 frame is fairly flat and straight unlike the 96 that is not. extensive floor work will need to be done to make it look/fit right. take a look at tigger stories truck to see what i mean. his is a task force truck but the same problem is their with the floor. just remember the more info you give us the better answer we can give you.
06-09-2009, 04:51 PM | #9 |
i think he means will a 96 short bed "bed" fit on his 49 truck chassis and cab...is that what the question is ???
06-09-2009, 05:42 PM | #10 |
well then thats a different story. why didn't he just say that in the first place. like i said before info was too vague. the box should fit the frameas long as yor ad is a short box to begin with but as far as looks it will be too wide where it meets the cab. meaning the steps on the step side box. if it is a fleetside box the it will be too wide entirley. and it will look like a%%. if it is a step side you will need to rework the steps where they meet the cab that should be all. not gona say that it won't look right at all. i have seen it done but on the task force trucks only. the ad cab is a bit narrower than the taskforce trucks.
06-09-2009, 06:11 PM | #11 |
Sorry for the confusion. This bed is from a full size truck.
06-10-2009, 10:14 AM | #12 |
a quick measurement on my '94 full size bed is 68" from outside top of bed side to outside top of bed side. the bed sides then bow out another 2" each side, for a full width of 72". Make sense?
Not sure on the width of the AD cab, but I'm sure this will be too wide Also not sure on the length - mine is a long bed Last edited by MrTucker; 06-10-2009 at 10:15 AM. |
