I need help W/Spindle & springs
This is my first time posting a question. I'm a christmas tree farmer in snowy North Plains, Oregon. I'm just starting to restore my father inlaws 66 stepside which my wife took her drivers test in years ago. I want to lower the truck but not to the extent of draging over the speed bumps. So i'm asking you to help me with maybe pictures and spec's of your trucks. The attached pictures are of me and my wife bringing the truck home from Eastern Oregon.
It's Better With Nitro
Re: I need help W/Spindle & springs
Welcome. Replacing the springs with a shorter set might be less expensive and involved than replacing the spindles with a drop spindle set. Most of the vendors have different spring heights for a desired stance.
However, if you are doing a disc brake upgrade, the drop spindle would probably be the best route to take. Good luck and let us know if you have any other questions.
One day...
Ya the drop spindles will give you a better ride but the springs work ok too just depends on how much your wanting to spend and lower it.
1 thing at a time is progress.
Welcome aboard from North georgia.
Here is a link to a page that shows pix of trucks at different stances and what it took to get there to give you an idea of what your looking for. http://www.earlyclassic.com/Tech.asp...=Stance+Photos Keep the info and progress pix coming.
Alan
Philippians 2:14-16 |
![]() Join Date: Oct 2006
welcome from nor cal very nice project
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Sep 2006
Here are a few pictures of a 3/4 drop. I want to raise the back up 1" for more rake.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Registered Asphalt Offender
5 1/2 drop front with 2 1/2 drop spindles 3 inch drop springs and 5 inch rear with drop springs, Doetsch Tech drop shocks on all four corners. All bought from CPP . This is probably lower than you want to go but it does meet your criteria as I have no trouble with speed bumps or anything else I've encountered. I will be going lower soon thanks to me winning a new set of four Air Lift Dominator Bags on another forum!
![]() ![]() 1963 C10 Short Fleetside Bed Big Back Glass 1974 C10 Short Stepside Bed 1982 S10 Shortbed 350 EFI V8 http://67-72chevytrucks.com/vboard/a...hp?albumid=140 http://www.hubgarage.com/mygarage/MEANlowGREEN http://www.motortopia.com/garage/cars/MEANlowGREEN http://www.myspace.com/jcsmeed |
Hollister, CA.
If you are planning a complete restoration with upgrades, then mabey the spindle/disc is probably the way to go.
As others have mentioned, it all depends on how low you would like to sit. If you would a slight drop, you could always cut 1 1/2 turns off the spring, and trim the bumpstops....this will actually still give you a decent ride. BTW, nice project you got there !!! Welcome from San Jose, CA..... ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
[QUOTE=
If you would a slight drop, you could always cut 1 1/2 turns off the spring, and trim the bumpstops....this will actually still give you a decent ride.:[/QUOTE] I hate to disagree with anyone but my truck rode like it had no suspension at all with just one coil removed and four new Monroe Gas Shocks. It rides so much better now, even with the extreme drop than it ever did on 40 year old cut factory springs. So I vote for at least new springs, mine are 3 and 5 inch drop springs so I would think a milder drop spring would ride superbly!
Hollister, CA.
Really ?
Did you trim or remove the stops, and install shorter shocks ?? As a rule of thumb, on ALL GM vehicles, you can cut 1 1/2 to 2 turns (MAX) , with correct shocks and still achieve a good ride. Currently, my truck has NO stops, and the coils are cut so much that they are loose in the spring pockets ![]() This is all temporary until....well..... I get to it !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 12-18-2008 at 12:19 PM. |
SIR
...HOWDY from southern oregon,I.M.H.O,wash it clean it up,get it running good,throw a cheap seat cover on it and DRIVE IT!!!.when you have all your plan figured out ,and the majority of your parts gathered up,then go for it...It's better than most of us started with,Good luck.....
66long low fleet http://community.webshots.com/user/LVNR66 |
