Old 02-12-2013, 03:09 PM   #1
register
register's Avatar
in bed tire mount
Which is the best one that looks close to
the real thing, when the truck was ordered with that option?
The only one I can find is LMC and I'm always hesitant
when ordering from them!
I've tried to do a search and a member built this trick looking one
but for a guy that can't weld I need to buy one
Thanks in advance
register is offline   Reply With Quote
Old 02-12-2013, 04:09 PM   #2
Coley
Coley's Avatar
Smile Re: in bed tire mount
The original in bed spare tire is a bolt in item.
I think you have to drill holes into the inner edge of the upper box side, which is what would have happened on the assembly line, and then I believe it uses/shares a couple of the lower box/bed mount bolts.
If I was you I would contact Bill Peeters out at Bills (Classic) Truck Shop in Oshawa (905.725.3460)....he can help you out all day long on this one with either the parts or the procedure.
Good luck and post some pics when you get it done!!!
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-12-2013, 04:11 PM   #3
Scott>72-GMC
Scott>72-GMC's Avatar
Yep bolt in
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-12-2013, 04:18 PM   #4
register
register's Avatar
Tried Bill no go
Have been looking for sometime
And probably going to give up and go
Aftermarket
So seeing what ideas are out there
As far as aftermarket
Old 02-12-2013, 04:23 PM   #5
Scott>72-GMC
The one in mine looks like the Lmc mount
Old 02-12-2013, 07:39 PM   #6
kevmac
kevmac's Avatar
Got one, give me a shout
kevmac is offline   Reply With Quote
Old 02-12-2013, 07:40 PM   #7
Daner
Daner's Avatar
If you are interested in a picture of a original I could snap one or two this weekend when I go home.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 02-12-2013, 08:19 PM   #8
register
register's Avatar
That would be great when you have a minute!!
Old 02-12-2013, 08:45 PM   #9
JOJABOY
I am having a buddy fabricate one for me. Only mine is going to be mounted to the back of my tool box on the passengerside.
JOJABOY is offline   Reply With Quote
Old 02-12-2013, 09:25 PM   #10
100%Chevy
Here's the one on my original 68-
Mike.
100%Chevy is offline   Reply With Quote
Old 02-12-2013, 09:29 PM   #11
register
register's Avatar
thanks
Old 02-12-2013, 09:33 PM   #12
kevmac
kevmac's Avatar
Mike.
BINGO!!!!! That's it
Old 02-12-2013, 09:36 PM   #13
register
register's Avatar
how does it mount at the base?, I see the top by bolts
Old 02-12-2013, 09:39 PM   #14
SS Tim
SS Tim's Avatar
For a factory RPO P13 or an accessory these should help picture wise. Remember there were also aftermarket versions too. The assembly manual also has the factory locations for SWB and LWB trucks.
SS Tim is offline   Reply With Quote
Old 02-13-2013, 06:00 AM   #15
JCD
JCD's Avatar
I have a question..
I have the optional spare tank, that has the welded in square tube going down to the floor of the back.
Could you order the exterior tire with this tank option?
Would they put the tire in a different place.. or would it still fit?
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 02-13-2013, 06:52 AM   #16
SS Tim
SS Tim's Avatar
If you have the RPO NL2 factory aux tank the cover is not welded down. But to answer your question, we answered this a while ago for Pete and I have since seen a SPID for a truck equipped with both NL2 and P13.
http://67-72chevytrucks.com/vboard/s...d.php?t=493373
Old 02-16-2013, 10:56 PM   #17
Daner
Daner's Avatar
So was there a certain side/placement of the carrier if it was factory? On fleetsides I mean.
Here are my pics.
Dane
Old 02-16-2013, 11:01 PM   #18
register
register's Avatar
behind the driver
so it also does not affect the blind spot when looking right...
Old 02-16-2013, 11:10 PM   #19
Daner
Daner's Avatar
That makes sense. So mine is opposite :P
Dane
Old 02-16-2013, 11:14 PM   #20
Daner
Daner's Avatar
Dane
Old 02-16-2013, 11:27 PM   #21
pritch
pritch's Avatar
Originally Posted by register View Post
behind the driver
Mines way behind the driver.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-17-2013, 01:48 AM   #22
SS Tim
SS Tim's Avatar
The were sold over the counter as accessories too. People would put them anywhere. The correct locations are just forward of the left wheel tube. it was fairly common to see them as dual mounts too behind the tubs, but this was not "factory"
