03-22-2019, 07:24 PM | #1 |
Opinions needed: How bad is this exhaust manifold face?
Pulled the driver's side exhaust manifold (rams horn old school style) off today to try and fix an annoying leak/tick. I know these were mounted factory directly to the heads, no gasket involved. My truck had gaskets, the "slide-in" kind, but they didn't look to be in great condition. I cleaned up the faces a little with a broad, flat file, but didn't want to go nuts of course. I see pitting, but I don't have any reference to know how bad or normal that is.
Trying to decide if I need to put new gaskets in, or if I can simply use a bead of copper/silicone high-temp exhaust gasket maker to account for the pitting. So, the questions: How bad are these faces (particularly the last photo)? And what's your opinion on the probable success of copper/silicone gasket maker and nothing else before reinstall? Thanks!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
03-22-2019, 07:40 PM | #2 |
Re: Opinions needed: How bad is this exhaust manifold face?
Maybe get some header gaskets, cut them to fit, put on your silicone on,let it sit overnight,and I think you would be good to go.
03-22-2019, 07:44 PM | #3 |
I don't think they look that bad.
A good machinist with a milling machine can shave off some material to clean them up. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
03-22-2019, 08:50 PM | #4 |
I would hit them with a little sand paper, some new gaskets and not even worry about it.
03-22-2019, 09:20 PM | #5 |
Does not look to bad, continue with what you were doing with the file. Span the center and 1 side at a time. Keep all 3 as flat as possible.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
03-22-2019, 09:30 PM | #6 |
Fortunately for me I have a rather large vertical belt sander that I run my manifolds through to check them. Doesn't look like it would take much to get that relatively flat to me.
03-22-2019, 10:34 PM | #7 |
Who Changed This?
Looking good but they'll still leak the way they are. You can buy a sealer from the parts store that will fill in the gaps. One brand is Versa-Chem Exhaust System Joint & Crack Sealer. Worked great on some severely pitted manifolds I had on an old Buick. I dressed them pretty flat with a mill file, but there were still gaps that traced from inside to outside the manifold.
03-23-2019, 09:19 AM | #8 |
Thanks for the input, everyone.
I filed them a bit more, but didn't want to risk making the entire manifold out of plane - plus, the rear face (last photo) has some fairly deep pitting that would have required a lot of material removal to get completely flat. I used some Fel-Pro gaskets from the parts store down the street along with a healthy layer of copper/silicone gasket maker to fill the pitted areas. Bolted them up last night, will check it this afternoon after it's had some time to cure. We'll see!
03-23-2019, 08:11 PM | #9 |
Just closing this thread out for future reference. The gaskets + high-temp sealant did the trick!
03-23-2019, 10:12 PM | #10 | |
The Older Generation
Thanks for the followup.... A lot of people don't do that. LockDoc
03-23-2019, 10:22 PM | #11 |
The threads that do get resolved are always the most helpful to me... so I make a point to always close my threads with a resolution, if I found one, that is.
03-24-2019, 10:05 AM | #12 |
Yes thanks for the follow up.
