horn relay
my horn dont work and i am getting a battery drain can i get a horn relay at part store too fit our trucks or do i need to contact one of our venders for it?
Horn relays don't cause a lot of problems. Does it click when you push the horn button?
Try unplugging it to see if the drain goes away. Jim |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Jim's right about the horn relay. They are usualy trouble free.
However, if you ever do need one, they are a common parts store item.
Active Member
My aftermarket steering wheel adapter is off just enough where the plunger touches the side and keeps the horn contact made. I didn't notice this until I changed out steering columns. The PO had cut the horn wire and unplugged the horn. I didn't find the horn relay was constantly on with new column (I never connected the horn back up) until I killed a battery and alternator. You would figure that the horn circuit between the horn button and relay would be on a fuse...
