11-04-2013, 04:59 AM | #1 |
Definitive Rear End Swap
As always I've scoured this forum, that forum, all the forums! Need a rear end for a '49 - '54 frame.
Does anything swap direct, spring perches, leafs and all? I saw some speculation mid 70's Camaros do but found nobody that had actually done it and had pics. Suggestions? By this I mean, suggestions of something you've done that worked? |
11-04-2013, 10:03 AM | #2 |
Re: Definitive Rear End Swap
There are no direct swaps. All will at least need spring perches relocated, unless you order a new one from a supplier like Currie.
1949 Five Window, 1973 Step Side, 2000 Z71 |
11-04-2013, 02:45 PM | #3 |
http://www.chevytrucks.org/tech/ifs&rearend.htm scroll way down
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-04-2013, 05:43 PM | #4 | |
I was sorta bummed after reading the Ford 9" sucks more power to turn. That is what my '57 TF panel has.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
11-05-2013, 12:36 AM | #5 | |
11-05-2013, 09:29 AM | #6 |
After the deer repairs are complete, I will consider the rear end gear ratio change.
11-05-2013, 01:20 PM | #7 |
When I built my '52 Chev panel, I swapped a Ford Maveric 8" straight in without changing anything.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
