09-14-2016, 06:07 PM | #201 |
Re: Hydroboost Mounting Plates
Got my bracket in today. Fast shipping and great packaging. BTW bracket fits 94 Astro Hydroboost in a 72 blazer! perfect! Thx captain!!!!
72 blazer 4x4 4" 35's 02 f150 work truck 15 f350 super crew long bed 6.7 4x4(stock but loaded) 02 f350 horse hauler 7.3 (need to sell) |
09-14-2016, 11:45 PM | #202 |
60-66 Nut
Thanks for the good words.
Just to be clear. What you bought is not a hydroboost mounting plate. You decided you did not want one. What you bought is a '67-'72 booster bracket.
12-25-2016, 11:32 AM | #203 |
Forgot to post when I got the mounting hardware a while back... But it fits real nice and is very nice quality. Thank You!
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
12-27-2016, 01:19 AM | #204 |
60-66 Nut
Thanks for posting pics of your installation.....looks good. Would you mind posting some info on the hydroboost and master you purchased? I know that the proportioning valve is the Wilwood 260-11179.
01-16-2017, 10:03 AM | #205 |
Thanks... yeah it was all bought as a Wilwood kit on ebay. The plate that comes on it lined right up with the mounting bracket I got from you. Worked like a dream. Didn't have to do anything but bolt it all up.
03-20-2017, 06:39 PM | #206 |
I would like the same bracket but with mounting holes and black powder coat will be paired with a 2012 2500 Silverado unit.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-20-2017, 11:23 PM | #207 |
60-66 Nut
I will send you a PM with ordering and payment info.
03-20-2017, 11:27 PM | #208 |
CaptainFab-
I got an 85 K20 that I'm converting to a manual trans & hydro-boost. I'm having a hell of a time finding a pedal assembly for such that doesn't cost a fortune. Locating a manual/vacuum version seems to be much easier (and cheaper!). So, I'm thinking I'll first convert it to manual clutch/vacuum (its currently auto/vacuum) and then use your bracket to convert it over to hydroboost. Am I understanding this right? You have a bracket that properly re-positions the hydro-boost unit to replace the vacuum unit? Does this correct the geometry difference in the pin height on the brake pedal? Any mods needed to the pushrod? Thank you in advance, Mike |
03-20-2017, 11:35 PM | #209 | |
60-66 Nut
I do not make any booster brackets or hydroboost mounts for the square bodies. There is no need since factory components are readily available. I do not know what the hole pattern would be if the factory booster brackets were removed from the vacuum booster. Those are riveted to the booster.
03-21-2017, 12:47 AM | #210 |
This is what I am looking for. Plate with 5 holes, booster hole and four mounting holes. It will be used in a 72 k5
07-05-2017, 12:50 AM | #211 |
Are these still available?
07-05-2017, 11:17 PM | #212 |
60-66 Nut
I fabricate all of my products everyday. Exactly which item are you asking about?
07-06-2017, 12:15 AM | #213 |
The hydro boost plate that mounts to the firewall in pic above this post
07-06-2017, 11:37 PM | #214 |
60-66 Nut
That is not a regular production part. It was a special order for member Curtb1971. At the time I had a couple extra laser cut but I do not know if I have any left. I will have to look when I get top the shop tomorrow. You do realize that with this style you will have to open up the center hole to accommodate the nut on the hydroboost? Also this style does not lend itself very well to moving the pushrod attachment point on the pedal down 1"
07-24-2017, 07:14 PM | #215 |
Pm sent for purchase of a bracket sir. Thanks!
Posted via Mobile Device |
07-24-2017, 11:10 PM | #216 |
60-66 Nut
I replied to your PM from this morning.
09-09-2017, 05:09 PM | #217 |
PM Sent to Captainfab
09-09-2017, 10:59 PM | #218 |
60-66 Nut
I replied to your PM.
09-10-2017, 05:33 PM | #219 |
PM sent
65' Chevy C-10 Shortbox |
09-10-2017, 05:55 PM | #220 |
Do you know what "size" the nut is for the H B unit?
Where can I find a new one ?
09-10-2017, 11:13 PM | #221 |
60-66 Nut
Are you talking about the large nut that secures the HB unit to the mounting plate?
09-11-2017, 08:42 AM | #222 |
Yes, what thread size is the nut?
09-11-2017, 11:13 PM | #223 |
60-66 Nut
I really don't know and I forgot to take a look at one today. I do not think it is a standard thread pitch. The factory nut is 4 sided and is thin.
09-16-2017, 06:02 PM | #224 |
Pm sent for bracket, 64 c20
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-16-2017, 10:56 PM | #225 |
60-66 Nut
