Old 07-30-2008, 03:37 PM   #1
sleepertruck72
sleepertruck72's Avatar
Cool Trailer maintenance
I am replacing the rear wheel cylinders and axle seals on my C-20 and it made my think of doing it on my C-20 trailer. I dont think it needs to since the brakes arent being used on the trailer.They dont seem to be leaking or anything, but then again it would be hard to tell since it is used every now and then. It doesnt have any obvious signs like my daily driver. It loses fluid in the master cylinder and left some stains on a driveway one day. Should I do anything other than replacing the fluid in the rear end(which I already did). I eventually want to replace the axle (Dana 60) with a straight tube 8 lug trailer axle just to save some weight and have a spare axle. But that can wait.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 07-30-2008, 04:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Trailer maintenance
your brakes on the trailer are probably empty.
Old 07-30-2008, 05:23 PM   #3
Andy4639
Old member
Andy4639's Avatar
Have you done the bearing's lately. That's the main thing to keep the grease in the bearings.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-30-2008, 05:37 PM   #4
Longhorn Man
he said he already chainged the oil in the rear, and since there is no grease anywhere on a dana hub, he is set.
