L88 hood on our trucks.
Has anyone made or seen an l88 hood on our trucks? I'm thinking of fabbing one up but wonder how it will look.
![]() Posted via Mobile Device
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
Re: L88 hood on our trucks.
my bet is will look great!!!
Cluster King
![]() Join Date: Nov 2012
I think it may look ok if you figure out what to do in the middle. Since the L-88 scoop and the hood body line do not match. It might take some trail and error to get it looking right.
While it could look pretty good a few things come to mind.
Are you planning on fabbing it from scratch or using a vendor scoop and attaching it? If so get the dimensions and lay it out with tape. Are you planning on making it a true cowl induction hood and hot air extraction vent or is it to be just a bump?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#5 | |
Im planning on fabbing it from scratch so I can match and remove certain body lines. Im not sure how functional I will make it. I'm a long way away from body work but just lining up my ducks to see where Im taking my build.
Proprietor of Dale's Corner
hey Rob, I had one on a camaro and they are water catchers that gets to be a pain
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#7 | |
