Side window repair
Hello, I normally hang out on the 67-72 side but troll here occasionally.
A friend has a 64 and said the driver's side window glass has come out of the regulator. Do I have to pull the glass and regulator assembly to reinstall the glass? Is it glued in, use friction tape, or something else? If I have to pull the regulator assembly, is there a link to the steps (I tried the search and came up empty)? Any help is appreciated.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
Re: Side window repair
try not to pull regulator! the glass goes into the track with sticky tape, you can unscew the track from the regulator just 3 screws, take out track, put tape in replace and stick the glass in. check the rollers while you are in there!
Easy Does It
did the window regulator just come off track? if so it just needs to be realigned . if the glass came out of the track then it might be easier to pull the regulator out to get the glass back into the track.
Thanks for the options. I haven't looked at it yet to see if it is out of the track or off the regulator. Hopefully will check on it today.
