Old 01-05-2012, 11:13 AM   #1
Hazieview
Building Dreams out of Dimes!
Can not find lower radiator hose that fits! please help!
Has anyone had problems finding a lower radiator hose that fits?
I'm running a BeCool radiator with a 1 5/8" outlet.
A Tuff Stuff long water pump with a 1 3/4" inlet.
This being said, every single stock molded hose has an i.d. that is too small. The only flex hose i found is a Dayco and it kinks on the ends where there is no internal wire that prevents kinking. It kinks because I have to bend the Hell out of it in order to dodge the frame rail.
Any suggestions? Please help!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 01-05-2012, 01:07 PM   #2
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Can not find lower radiator hose that fits! please help!
you can go to your local store and buy a spectra megna kool radiator hose kit i run them on my truck and they work great.
bowtiemanchevyman is offline   Reply With Quote
Old 01-05-2012, 02:23 PM   #3
SCOTI
SCOTI's Avatar
A quick/east fix is to use muffler/exhaust pipe reducers for connecting 2 different hoses. Run a hose that fits the water pump outlet to the reducer that necks down to the hose size for the radiator.
I've done this on 2 different applications (my old 78 ElCamino & in my 68 Beater) w/no issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2012, 02:25 PM   #4
Hazieview
Do the spectre hoses kink at all? I have to make 2 sharp bends.
SB400 350th
Old 01-05-2012, 10:35 PM   #5
bowtiemanchevyman
no mine make two 90 dergree turn and its just fine
