06-26-2013, 10:49 AM | #1 |
Lug nuts for Rally wheels?! HELP!
I've got a few different styles of lugnuts on my truck now, and on all four wheels the center caps would just fall off if I tried to put them on...
What lugnuts do I need?! something with a wider taper? Washer? some sort of GM lugnut?! my wheels look bare without the rings and centers... Also if anyone has pictures so I can get a little better idea of what I'm looking for.
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! |
06-26-2013, 10:53 AM | #2 |
Re: Lug nuts for Rally wheels?! HELP!
If it's the center caps for our year trucks the caps are held on using three bolts around the perimeter of the cap, the lug nuts don't hold the cap on.
Posted via Mobile Device |
06-26-2013, 10:58 AM | #3 |
Charlie Daniels w/ a Tq Wrench
Yep, the correct center caps bolt onto the wheels with three bolts. If you have the later 88-98 style caps, they thread on to the external threads of the special lug nuts using plastic caps.
Maybe you can post a picture of what you have, and what you are trying to do so we can better help you?
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
06-26-2013, 10:59 AM | #4 |
The 90's era center caps have trouble hanging on to the lugnuts on our trucks..They have the larger metric lugnuts. I bent the flanges that hook on and it helps a lot..Is there a larger o.d. size nut that would fit on the older smaller studs??
06-26-2013, 11:03 AM | #5 |
These hook on.. |
06-26-2013, 11:07 AM | #6 | |
06-26-2013, 11:13 AM | #7 | |
06-26-2013, 11:26 AM | #8 |
and no one laugh, I know the tires are small :p I just needed something to get me by :p and that's the best picture I have of the wheel up close. The centercaps are actually in the truck, so I'll get a picture of those when I go to lunch.
06-26-2013, 11:34 AM | #9 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-26-2013, 11:35 AM | #10 | ||
06-26-2013, 12:26 PM | #11 |
Just went to the parking lot to snag a couple pics of the caps.
06-26-2013, 01:47 PM | #12 |
Those are truck rally wheel centers. They bolt to the wheels via the 3 small screw holes. The lug nuts will not hold them on. The lugs would be the type with the shiny caps on them. Rich84 is showing the 'new' style (88 up) that are held on by plastic lug caps that screw to the lug nuts.
If you don't have the holes in your wheels I suppose you could drill them.... The screws are a large head self tapper.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
06-26-2013, 01:53 PM | #13 |
The one that I have in the picture is what I thought the O P was talking about..Those are fake lugs...The cap is friction fitted on the lugnuts..If not careful they pop off very easily.
06-26-2013, 01:59 PM | #14 | |
06-26-2013, 02:13 PM | #15 | |
06-26-2013, 02:36 PM | #16 |
I know what the rallies look like.. sorry for the confusion. I thought we were past this, but we'll recap.
I have 4: 4 slot steel wheels, 4: center caps, and 4: beauty rings... So I guess I'll just drill my wheels. and what length bolt would be appropriate?
06-27-2013, 12:01 PM | #17 |
Calm down there hot rod..... Keith was not attaching you. He was posting a picture for the record so that in 2yrs when someone else stumbles onto your thread because they have a similar issue they will understand what they are looking at and the differences.
As far as the "bolt" it is a really a self tapping screw (I thought we already covered that! ). They don't need to be any longer than the thickness of the wheel and the thickness of the cap together. I can get you a picture of a screw off of mine this evening if nobody can get you the info quicker.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
06-27-2013, 12:10 PM | #18 | |
and yes, self tapper :p
