09-16-2004, 10:57 PM | #1 |
Got Light Emitting Diode?
longhorn man...i need help again
i think you helped me with this before but it might have been crazy L (one of the longhorn guys) there are 2 different sizes of spindle in 81 for a light and heavy 1/2. what are the 2 sizes and on what part do i measure, the widest???thanks for the help
Ben
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
09-16-2004, 11:26 PM | #2 |
Fabricate till you "puke"
the thickness of the rotor is 1" on the light version, & 1 1/4" on the heavy. Im not sure about diffs in the balljoints, but if you use all of the corresponding parts on the swap, you should be able to use either setup. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-16-2004, 11:33 PM | #3 |
you're a stud. i need to find out cause i am going to do 6 lug disc. thanks a bunch
09-16-2004, 11:41 PM | #4 |
1.381 inches, close enough. so those are the same as 71-80 spindles and i can use the 6 lug disc rotors.
09-16-2004, 11:43 PM | #5 |
its all about the +6 inches
Thanks crazy...I woulda just looked at the computer and said "duh...I dunno".
09-17-2004, 12:01 AM | #6 |
Yup, 1.381 is close enough.....i think the 1.250 is a minimum thickness, when doing brakes. crazyL
