Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-11-2021, 09:23 AM   #701
regan wilson
regan wilson's Avatar
Re: Ok Boys and Girls it's Storytime
Well it looks like I have a free day today. I'm going to start on it this morning. If I do anything pic worthy I'll post up in the morning. I have a few ideas in my head.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-12-2021, 08:23 AM   #702
regan wilson
Well I got started yesterday morning. The old trusty beer box template. I had to do one for each side.
Old 03-12-2021, 08:28 AM   #703
regan wilson
I started by cutting just enough of the bracing off the pieces so it would still have some support.
Old 03-12-2021, 08:35 AM   #704
regan wilson
And then the point of no return. I took a hole saw and drilled both pieces.
Old 03-12-2021, 08:40 AM   #705
regan wilson
Then I had to make a decision on where I was cutting them. I'm going to do some of the welding from underneath but I have to weld some up top. The problem is minimum access to grind and smooth it out. I also tack welded the braces back when I made my cut.
Old 03-12-2021, 08:44 AM   #706
regan wilson
I was back and forth in and out of the truck taking baby steps grinding and testing. Of course my measurements were a tad off but it will be ok.
Old 03-12-2021, 08:50 AM   #707
regan wilson
I got both pieces just about ready to go. I had enough after six hours of eating aluminum oxide. I have a bunch of prep work to do. I need to get the truck off the ground. Pull the tires off again. Unhook all the battery cables and ignition box. Then figure out where to start welding. I may also try to adjust the bed before hand. I may have to weld the braces to the frame to get the floor to lay down so I have to be sure before I start.
Old 03-13-2021, 08:33 AM   #708
mongocanfly
mongocanfly's Avatar
repairs look great Regan..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 03-14-2021, 08:59 AM   #709
regan wilson
Friday afternoon I came up with this idea. I took some sheet metal and trimmed some pieces to help fill the gap for welding.
Old 03-14-2021, 09:02 AM   #710
regan wilson
I was able to form these into the hump and tack them in.
Old 03-14-2021, 09:05 AM   #711
regan wilson
Finished product and ready to fit. This little project took all afternoon.
Old 03-14-2021, 09:10 AM   #712
regan wilson
I got the pieces stitched in yesterday. It's slow going when you have to use a die grinder to smooth out the hard mig welds. Ken came out and provided a second set of eyes for tacking the tubs back in. The passenger side tub is soup bowled but I don't know if I can fix it. I have some more metal work and then I get to move on to paint and bed liner.
Old 03-16-2021, 07:26 AM   #713
regan wilson
I got the bed repairs looking good enough to cover with bed liner. I'm tired of working on them. Lol
Old 03-16-2021, 07:28 AM   #714
regan wilson
Oh the joys of masking off this mess. I think it took me two hours to do all this.
Old 03-16-2021, 07:35 AM   #715
regan wilson
I went ahead and sprayed the bars. I've got a few runs to deal with and then I'm spraying it again. Afterwards it dawned on me I used satin black before and this is semi gloss Dupliclolor. I hit it with some grey Scotchbright and it looked pretty good. I'll still respray it though. Then I get to try and seamseal the tubs. That's going to be a task because it's hard to access everything. After that I will attempt to spray bed liner.
Old 03-16-2021, 08:54 AM   #716
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good.
Here is a tip next time when masking odd shaped items like your fuel cell vent tube or brake lines. Get some dollar store aluminum foil, just wrap it around the odd shape, tape the end for a clean line. Works for a lot of different things, I used it on suspension parts too.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-17-2021, 06:48 AM   #717
regan wilson
Thanks Greg
Old 03-17-2021, 06:49 AM   #718
regan wilson
Originally Posted by aggie91 View Post
Looks good.
Thanks Karl. I may try that when I mask off the cage so I can spray the bed.
Old 03-17-2021, 06:53 AM   #719
regan wilson
I got some seam sealer in yesterday afternoon. I also scuffed and repainted the monkey bars.
Old 03-17-2021, 06:55 AM   #720
regan wilson
I don't think this shock mount has been out in over 15 years. I cleaned it up and put a few coats on it.
Old 03-17-2021, 06:58 AM   #721
regan wilson
This is the same paint I use on my Dodge Dually wheels. Hopefully it just looks clean and black. The bars are black to make them less noticeable. The same reason the bars on the inside are body color.
Old 03-17-2021, 07:13 PM   #722
71Dragtruck
71Dragtruck's Avatar
Good to see it fixed and almost ready to roll again.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 03-17-2021, 09:11 PM   #723
regan wilson
Thanks Monty. I hope to be done with it by Sunday. We have a race in Houston Tx in a few weeks.
Old 03-22-2021, 09:00 AM   #724
regan wilson
Well I got it done on Sunday as planned. The truck needs a real good cleaning and it will be ready to go. I'm hoping this new stuff is a game changer.
Old 03-22-2021, 12:59 PM   #725
71Dragtruck
Looking good!
Sponsored by:
Hard Candy Customs
