![]() Join Date: May 2007
16" Factory Wheels?
Thinking of going back to the factory look of the steel wheels and dog dish caps on my 78 K20 but I don't want the hassle of 16.5 tires. Anyone know of a replacement steel wheel in 16" that will work with the factory caps?
1980 GMC Sierra Grande C15 1987-1992 1988 Chevy Silverado K1500 1992-1996 1978 Chevy K5 Blazer 1998-2002 1998 GMC Sierra SL K2500 2002-2010 ![]() 2007 GMC Sierra Classic 2500HD LBZ 2010-Present 1978 Chevy Silverado K20 2016-Present |
Re: 16" Factory Wheels?
Not sure on the factory hub caps https://www.summitracing.com/parts/w...0804/overview/
GM made 16" rims forever. My 76 came with them. I think they were optional in 76 though. I always run dog dish hubcaps on all of my trucks. I like the old simple style over flash on my work trucks. GM 16" steelies should be easy to find.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Your K20 should have 8 lug wheels - 16" rims for it should be plentiful.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
16" were factory on light duty 3/4 tons, I had an 87 with them. Also Ferd and Dudge wheels of the era used the same bolt pattern with a larger center hole, and available in wider sizes too. Somewhere on here is a list of the years that fit (everyone eventually changed patterns). IIRC there is a Ferd heavy van wheel that is quite a bit wider. I know there is a thread in here somewhere, just can't remember if it's in squares, drivetrain, or 67-72's. Search is your friend!
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
What about a 16" 6 lug steel rim to accept hubcaps? Were they ever available?
1982 K10 SWB 1987 V20 - Sold - Doh! |
I dream of those wheels but I don't believe they were made. I don't think the newer 16" 6 lug wheels have the right back space and probably won't accept our hub caps.
No, the GM 6 lugs were all 15". There 'were' 16" 6 lugs hubcap capable wheels on the heavy halfs in the 69-72's but I don't think they fit over disc brakes. I expect that there are aftermarket versions though.
Just a note, the truck pictured has 16.5x8.25 wheels. There are also 16.5x9.75 factory wheels out there. Going with factory 16" rims means you are stuck with the skinny 6.5 width, unless you go custom.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
Positive about that? Not saying you are wrong, just really curious. They had the 16x5 C10 wheels optional at one point (my old '79 had them) but they are uncommon. I've always wondered if there was a 6 lug version to go along with those.
![]() Join Date: Apr 2012
The answer would be yes.
wheel vintiques makes a 16x10 wheel that takes the hubcap. they run about $100 apiece. I need to start a thread and see how many people would buy them in 17" and maybe we could get them to make them. I need the 17" to clear big brakes but want the hubcap look.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
