10-12-2008, 08:38 PM | #1 |
What Do I Got here?....(Trans & X-Case)
Opps....Missing the "I"....." what do I got here"....
Can anyone tell me what I have here....I'm a real Newb on the 4x4 stuff....I just began a frame-off on a 70 k-10....Just trying to figure exactly what trans & X-case I have..... Thanks a bunch! Dan My new build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 10-12-2008 at 08:57 PM. |
10-12-2008, 09:17 PM | #2 |
Re: What Do Got here?....(Trans & X-Case)
Looks like SM465 trans & NP 205 transfer case
10-12-2008, 10:45 PM | #3 |
Born Psycho
i agree with the above statement-465/205. BULLETPROOF COMBO.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
10-12-2008, 11:54 PM | #4 |
Thanks guys!
I'm guessing that these are probably original to the truck (as the engine is)...would that be a good guess?...anyway to tell....Partial VIN stamped anywhere? Also, my plan was to have a PRO go through them...even though they both seem to operate fine...Though I only drove the truck about 20 Miles getting it home.....then she started getting torn apart.....What is a ballpark price it should cost for a quick overhaul on these units? Dan Last edited by Rack Man; 10-12-2008 at 11:56 PM. |
10-13-2008, 12:09 AM | #5 |
I did mine myself, $350. in parts (ebay). Not sure what a shop would charge.
10-13-2008, 03:27 AM | #6 |
Yepper... SM465 and an NP205.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
10-13-2008, 04:44 AM | #7 |
KEEP ON TRUCKIN'
My SM 465 looked like a grenade went off in side it. After all was said and done it was $1300.00 dollars. Yours is in good working order, shouldn't be more than $700.00 I would think.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
10-13-2008, 07:55 AM | #8 |
NP205 rebuild kit:
169.00 http://northwestfab.com/rebuild.html They have a bearing and seals kit for the SM465 as well. Why not do it yourself? They're not that tough to do. Pro will bill you 6 hours on the 205 and 8 hours on the 465. |
10-13-2008, 08:35 AM | #9 |
sdailey had his same combo done for about $1,000 I think...
I say do it yourself or just change the fluid and run it till you hear funny noises...of course then they might be to shot to run at all
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-13-2008, 09:55 AM | #10 |
Post Whore
Both units are pretty reliable - pretty unlikely that a rebuild woud be needed for either.
When I switched from a three speed manual to the SM465 like you have, I ran up to a local tranny shop and the guy there was nice enough to take a quick peak inside the SM465, I already had the top cover opened up. He was visually able to see that it was fine. Maybe you could get someone to do a quick visual inspection for you?? I then took it home and put in new seals and gaskets in both the transfer case and SM465. If I were you, I'd separate the tranny and look to make sure the coupler is in good shape, if not, replace it. Other than that, I wouldn't worry about an actual rebuild unless there were signs of problems.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-13-2008, 10:12 AM | #11 | |
The Few, The Proud
I had a local shop rebuild mine for right at $1000, but in my mind that was money well spent after seeing how the po "jerry-rigged" everything else on my truck. (FYI: Never buy a truck from a guy that owns a junkyard.) Some of the internals, synchros I believe, had to be replaced anyway. It's one less thing to worry about on my build, plus I've never tore into a tranny/t-case before. Good luck with your build.
Shannon |
10-13-2008, 01:18 PM | #12 |
Everything is work in progress
I just did my 205. It's easier then programing your vcr (do they still make those)
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
10-13-2008, 04:31 PM | #13 |
Post Whore
Re: What Do I Got here?....(Trans & X-Case)
Fixed it for you
10-13-2008, 05:02 PM | #14 |
now make it "what do I have here?" for the Grammar nazi's
oh wait, we don't got none of them on here...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-13-2008 at 05:02 PM. |
10-13-2008, 08:53 PM | #15 |
Shaddap!!
That`s a heavy chunk there,huh?Most of the time all that is needed is new seals*.They only break from running low on lube due to *see above.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-13-2008 at 08:54 PM. |
10-13-2008, 09:57 PM | #16 |
Those couplers, the sleeve between the output shaft on the tranny and the input shaft on the t-case, like to explode.
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
10-19-2008, 09:35 PM | #17 | |
Keepin it runnin!
Thanks! Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
10-20-2008, 09:17 AM | #18 |
