10-12-2008, 10:55 PM | #1 |
Born Psycho
Dana 44 posi question
i picked up a posi carrier out of a 67 GMC 2wd with a dana 44 rear end. will this carrier interchange with my dana 44 front axle under my 72 K/20. GMC has 3:07s and my 72 has a later 44 with 3:73s. i've tried the axle shafts and they seem to be a perfect fit into the side gears. come on 4x4 guru's, someone has to know the answer to this. i think it'll work but i'd like to know for sure before i gut my front diff.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA Last edited by jerry moss; 10-13-2008 at 09:19 AM. Reason: added info |
10-13-2008, 09:44 AM | #2 |
Re: Dana 44 posi question
Most likly it will fit fine. I have never worked on a D44 rear so I can't say for sure.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-14-2008, 02:36 AM | #3 |
The carrier break on a 44 is 3.92 and down, so there it will work. But I don't think it will work cause the 67 might be course spline, and the front is a fine spline. Pull a shaft from the rear and see how many splines, if it's 30, then it will work in your front.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-14-2008, 08:59 AM | #4 |
Born Psycho
thanks for the replies. i've already tested my axles and they seem to be a perfect fit. it's been a while since i looked at it so i'll double check before i tear my front diff apart.
so, it's safe to assume that a 44 "pumpkin" is the same whether it's a front or rear diff, they just got different cut gears depending on application-front or rear.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
