Old 03-14-2004, 09:18 PM   #1
smitty62
smitty62's Avatar
A 5-lug question.
I'm sure this has been asked before, but i can't find it--what years of 5-lug axles if any will fit my '68 differential? Thanks!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 03-14-2004, 09:46 PM   #2
I would thing you would be better off just redrilling your current axles to the 5 lug you want.
The newer axles (5lug) are wider. Only 1" I believe, but enough to require some extra work to make them work. Just redrill.
My $.02
Old 03-14-2004, 11:38 PM   #3
kaycee
kaycee's Avatar
My axles were out of a 74 and they were 3/4" wider on EACH side I made a spacer plate for EACH side and seem to be doing OK so far.I allso used the wider drums from donor truck in my 70
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 03-15-2004, 12:31 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Easy way...either have your axles inspected and redrilled for a 5 on 5 pattern, or locate a 71/72 rear.
