Prostreet 72
Cab corners before floor replace, or the reverse?
I need some advise here. I am to the point on my build (Green Monster 2nd 1972 truck) where I need to pull the cab and replace the floor pan. The cab also needs the cab corners replaced. The question is, which do you do first, the corners or the full floor?
Thanks; Chris
Prostreet 72 "Green Monster" 1972 Fleetside Build http://67-72chevytrucks.com/vboard/s...1&goto=newpost http://67-72chevytrucks.com/vboard/s...d.php?t=319041 |
Re: Cab corners before floor replace, or the reverse?
Do the full floor first. The cab corners you are going to want to line up with the outer rockers and doors.
You want to do the floor pan first not only because you have to line the body line up but the cab corners are a tight fit agianst the floor pan and you might even have to trim a little bit of the floor pan with some snips and it would make it harder to get the pan in without damaging the cab corners.
