Old 02-07-2014, 08:13 PM   #1
Reno
Reno's Avatar
67-68 front clip conversion
Wanting to swap out my 70 GMC Jimmy front clip for Chevy 67-68 sloping front clip and a guy tells me that my front fenders off my 70 GMC will work?
Can anyone verify this info?
If so then all I need is the radiator support, grill, hood, bumper and lower valiance?
Thanks in advance
Reno is offline   Reply With Quote
Old 02-07-2014, 11:52 PM   #2
Acorn
Re: 67-68 front clip conversion
Yes. I believe your gmc fenders are the same as 67-68 chevy. I was looking into this but I searched so much I can't remember where exactly I found that answer.....I think it was on gmcpauls.com website. Sure you could fint a definate answer by searching this forum.
Acorn is offline   Reply With Quote
Old 02-08-2014, 05:18 AM   #3
king drake
Yes there are the same as 67-68 fenders,I'm doing the same conversion myself,on my 70 jimmy,you just have to weld up the holes where the trim went.you need to replace everything else up front,inner fender are the same,you probably need to replace battery side,due to acid,eating up the metal.
king drake is offline   Reply With Quote
Old 02-08-2014, 12:42 PM   #4
jaros44sr
jaros44sr's Avatar
One more thing youll run into.....67-68s have a single core rad., so, if you are using anything wider youll have to modify the bottom mounting area as it hits the rad.
Good luck, as the '68 front end (with the side marker lights) is the best looking of the lot, JMHO
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-09-2014, 12:57 AM   #5
king drake
Ok,thats some good imfo,i which i knew that before the core was painted,well that area,want be seen, anyway.thanks,jim.
