08-20-2011, 02:10 PM | #1 |
Pics of Unmolested Bagged Trucks?
Here's the deal, I can't bring myself to cutup my truck for that laid out look. I've seen a few on bags where they retained the stock inner fenders and didn't cutup the bed. Yea they don't lay frame but they still look good. If they ever want to go back to stock it's not a big deal.
If you've done it please post pics and list your hardware. We all wanna know!
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
08-20-2011, 02:13 PM | #2 |
Old Skool Club
Re: Pics of Unmolested Bagged Trucks?
What you're talking about is a truck that has air springs, instead of coil springs, right?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-20-2011, 02:17 PM | #3 |
I'm not familiar with air springs. I'm talking about air bags in place of springs.
08-20-2011, 02:20 PM | #4 |
Old Skool Club
Check out Air Lift (Google it) and Firestone for them. Air springs are what get called Bags....because, it is the bag that is the spring.
08-20-2011, 02:20 PM | #5 |
Running something similar to this system from Air Ride Technologies. Some folks just piece them together.
08-20-2011, 02:34 PM | #6 |
IMHO, lowering a truck IS molesting it.
08-20-2011, 03:11 PM | #7 |
I hear ya. Thanks for the opinion. I'm sure that could be a thread of its own. Let's stay focused here let's see them pics!
08-20-2011, 03:59 PM | #8 |
mine was a little molested!! but I kind of liked it!! is that wrong?
08-20-2011, 04:14 PM | #9 |
What did you have to do to get it that low?
08-20-2011, 04:17 PM | #10 |
ToTM Winner
heres mine with a raised bed
ToTM Winner |
08-20-2011, 04:41 PM | #11 |
Just bagged the front, but had to notch the rear and cut the bed. With 20's you shouldn't have to loose the inner fenderwells, but to get it that low in the back, you will have to raise the bed floor or cut it.
08-20-2011, 05:11 PM | #12 |
08-20-2011, 05:19 PM | #13 |
08-20-2011, 05:20 PM | #14 |
Nice to see that you got your truck up and running. I bought your cab dolly from you sometime ago. This kit is what you are looking for. You will not have to " cut up the truck" to install it. Pretty much just opening up holes and some new holes. It is pricey for what you get, but no homework is involved. Just buy it and install it. I would not use the line that is supplied. I would use aluminum fuel line for the lines with push lock fittings. Other then that the kit is nice as kit as you can buy. One good thing about buying a complete system is that you have only one go to guy, this being Air Ride Tech. good luck, Daniel.
08-20-2011, 07:08 PM | #15 |
Slightly molested + mostly stock = Gumby
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
08-20-2011, 07:11 PM | #16 | |
Not picking on you but using your info as an example..... Everyone needs to be careful when reading & interpeting the info shared in these type of threads. Manxxman's truck looks really low for not having to cut things up. It also looks like he's also running super low profile tires which makes a big difference between rubbing & not. Try listing how you achived the drop in your pics w/a parts list & post up your wheel tire info as well (width, back-spacing, tire size, & specific mods if any were necessary). Nice looking ride Manxxman!
08-20-2011, 07:13 PM | #17 |
Not mine but what a thread like this needs.....
73-87 disc swap & drop spindles Bags in place of front coils (plate on top, cup on bottom) Home made rear c-notches (similar in height to CPP's/Porterbuilts bolt in stuff) Lowering blocks Bags bolted in place of coils Modified shock mounts Long/super adjustable Panhard bar 20x8.5's w/5.75"bs & 255-40-20 Toyo's 20x10's w/5.0"bs & 295-40-20 Toyo's Rear bedsides were modified to allow more wheel/tire room @ the bedsides.
08-20-2011, 07:22 PM | #18 |
Another that's not mine but I'm in good w/the owner....
Porterbuilt mild front kit: upper/lower tubular arms, bags, shock brackets OE 72 front disc brakes Porterbuilt mild rear kit: Dropped T/A's, tubular T/A x-member, shock relocators, long, adjustable Panhard bar Coys 20x8.5's w/5.25"bs 255-40-20's Coys 22x9's w/5.5"bs 265-40-22's Pre-70 'shorter' rear 12-bolt housing Bed floor cut out directly above the rear differential for clearance. Custom alum plate fabbed for a clean/functional 'cover'.
08-20-2011, 08:45 PM | #19 |
SCOTI, great postings! Exactly the kind of info I was hoping to get shared with the masses.
08-20-2011, 10:17 PM | #20 |
Cruzin
Gumby = one of the nicest trucks on this site wheels/tire combo is killer
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-20-2011, 10:22 PM | #21 |
Old Skool Club
Air Ride Technology is what I couldn't remember. Good stuff.
08-20-2011, 10:23 PM | #22 |
08-22-2011, 08:04 PM | #23 | |
08-22-2011, 08:17 PM | #24 |
Nothing to see here.....
no molestation on my old c10....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-22-2011, 09:00 PM | #25 |
Cruzin
^beautiful
