12-26-2009, 12:23 AM | #1 |
longbed to shortbed conversion
i have a 1969 c20 long bed that i wanna convert to a shortbed can someone please tell me how much i need to shorten the frame unger the cab and in the back also how much to you take out of the bed thanks ive read alot of stuff and hoping i just get a straight answer here thanks also do i have to do anything with the trailing arms? thanks
12-26-2009, 12:45 AM | #2 |
67-72 parts collector,…
Re: longbed to shortbed conversion
Here's a good tech article from ECE:
http://www.earlyclassic.com/tech.asp...20No!-Shortbed Plus many members have done it on here. Here's member Rokcrln's Project Low Buck: http://67-72chevytrucks.com/vboard/s...d.php?t=223158 Last edited by lolife99; 12-26-2009 at 12:48 AM. |
12-26-2009, 01:43 AM | #3 |
The Older Generation
There is a lot of different information in the FAQ forum. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". On that page go down to "Thread / Thread Starter: FAQ Index thread". When you get into that scroll through the different sections and you will find answers to questions you haven't even thought of yet.... I could have just posted a direct link but there is a lot of good info in the FAQ section and now the people that read this thread will know how to get to it. Thanks to board member Krue for indexing the FAQ's I shortened a frame using the instructions in the FAQ and it worked out great. I think there are also threads on installing air bags and static drops. You might want to check out the "Projects and builds" forum for some good info. LockDoc
12-26-2009, 04:03 AM | #4 |
Big Red - Now its a SWB!
if you have an 8' bed then you shorten the wheelbase 12" and you shorten the tail 8". If you have the 8.5' bed (longhorn) then you shorten the wheelbase 18" and the tail 8". hope this helps!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
