Brake help again
I need to know why the push rod on my right wheel cylinder keeps popping out of the front brake shoe. It happened again today and all you hear is it pop and then there goes my brakes all together. I have no idea why it keeps happening, so some help would be greatly appreciated.
1969 Chevy C10 250 straight six. Still a work in progress. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Brake help again
Wrong wheel cylinder? Drum badly worn out-of-spec and the shoes are pushed out so far that the wheel cylinder is overextended?
I have no idea, I replaced the wheel cylinder with one from o'reillys and it's popped out about three different times while driving it. Should I replace the brake shoes and they'll solve it from happening again?
What?
Wrong brake shoes?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
That's what I was probably thinking and just replacing them when I get paid again. Has anybody else had this problem and could help me out with finding the right solution to this? I'm sick of my brakes working fine and then having it pop out and having no brakes again.
What?
Make sure you have your adjusters correct.
When you take the drum off, is the adjust closed all the way down? Could be that you have them reversed, meaning they close when they should open. Each adjuster is specific to right or left side.
#7 | |
![]() Quote:
To rule out several possibilities while verifying proper installation, I'd swap sides with the shoes. Be sure that each wheel has a shorter shoe(primary) on the front and a longer one(secondary) on the back. sam |
