Old 01-31-2010, 06:06 PM   #1
Larry S
Larry S's Avatar
Question cutting bed crossmember for blazer tank?
I have a 69 c10 short bed fleetside. I bought a blazer tank kit to relocate form inside cab. I had it mounted in frame and thought all was good untill... I tried to sit my bed on and the crossmember left to right underneath the bed sits on the gas tank. What have you guys been doing in this case. The way im lookin at it, either I can knotch the frame (which im not fond of)where the filler port on the tank is and lower the tank about 2 inches, or I could knotch the crossmember in the bed about 2 inches to clear the top of the tank. Any info/ pics will be appreciated.
Larry S is offline   Reply With Quote
Old 01-31-2010, 07:46 PM   #2
roughedup72
roughedup72's Avatar
Re: cutting bed crossmember for blazer tank?
I think you're supposed to remove the cross member. Do a search on blazer tank installs and see if there is anything that can help you with this.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 01-31-2010, 07:57 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, remove it. grind down the rivets and pop them out. If you are talking about the crossmember that runs between the frame rails and is the rear most crossmember, and is originally installed from the factory and is a little crooked.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-31-2010, 08:00 PM   #4
Larry S
Larry S's Avatar
Im talking about the cross sill on the bed, not the chassis.
Old 01-31-2010, 08:07 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ya, I had to notch the crossmember under the bed on mine for the filler neck. I went with a aluminum 20 gal. tank from Summit. It was about 2" deep and about 6" wide. Didn't get into the part that mounts to the bed floor, though. I then ran the filler tube over to the stake pocket and did a custom filler like John Fabris designed. I just used a die grinder with cutoff wheel to do the notching.
Old 01-31-2010, 08:12 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Notch the bed cross member. I used a sawzall and a grinder with cut off wheel.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-31-2010, 08:13 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ya, I didn't pay close enough attention to the "bed crossmember" part.
Old 01-31-2010, 08:23 PM   #8
Larry S
Larry S's Avatar
USMCchevy, thats exactly what Im talking about. I bought this tank "kit" several yrs ago and have had it in my chassis and thought it was supposed to be made for our trucks. I had no idea the bed wouldnt set down like its supposed to til today when I was tryin to get back on the project.Oh well. i guess I'll get the plasma torch out and hack it out. Thanks!
