Old 01-27-2006, 11:01 PM   #1
69 COPO
Ignition Bezel
Can anyone out there tell me how to get the ignition and bezel apart to get it out of the cab? It seems like there must be a trick to it. It just spins and if you hold it with channel locks it still will not come apart. HELP!
69 COPO is offline   Reply With Quote
Old 01-28-2006, 12:53 AM   #2
jhow66
jhow66's Avatar
Re: Ignition Bezel
1st put it back like it was so it will hold itself. Insert key and turn to acc. Take a paperclip and insert in hole that is in key cylinder and push in and turn key to left at same time. Cylinder will now pull out with key.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-28-2006, 02:46 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Ignition Bezel
After you get the cylinder out, the bezel will come off. There is a flange on the cylinder to make it harder to pull the switch without the key.
This tool helps keep from destroying the bezel.
http://www.myoldtruck.com/vboard/showthread.php?t=6562
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-31-2006, 11:42 PM   #4
jimfulco
Re: Ignition Bezel
Some jiggling may be required during the process.
jimfulco is offline   Reply With Quote
Old 01-31-2006, 11:52 PM   #5
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Ignition Bezel
So if your key is really worn and comes out in any position its really hard to get the cylinder out?
That could explain a few things
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 02-01-2006, 12:53 PM   #6
farside847
farside847's Avatar
Re: Ignition Bezel
I spent a good 3 hours getting my old one out. Lots of "jiggleing the handle" if you know what I mean....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-01-2006, 01:02 PM   #7
stynchrr
stynchrr's Avatar
Re: Ignition Bezel
what if you lost the key? Is it still possible to get it apart?
stynchrr is offline   Reply With Quote
Old 02-01-2006, 01:19 PM   #8
Putter
More Cowbell....
Putter's Avatar
Re: Ignition Bezel
Cordless drill and a sharp bit will assist in that case /\
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-01-2006, 01:27 PM   #9
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Ignition Bezel
The benzel will come off, but what is holding it is the chrome or stainless cover over the key cylinder, if you dont have a key take a small screwdriver and pop the nickle size cap off the key hole and the benzel will unscew right off.
sneakysnake is offline   Reply With Quote
Old 02-01-2006, 01:28 PM   #10
stynchrr
stynchrr's Avatar
Re: Ignition Bezel
What part needs to be drilled out?
Old 02-01-2006, 01:29 PM   #11
stynchrr
stynchrr's Avatar
Re: Ignition Bezel
Ok I will try that.
