Old 11-14-2005, 12:39 PM   #1
greenvilledave
throttle linkage
I need some pics or advice about the throttle linkage going from the 250 to a 350 with an edelbroc proformer carb. thanks dave
greenvilledave is offline   Reply With Quote
Old 11-14-2005, 02:20 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: throttle linkage
With a cable.With a rod linkage, hope this helps and thanks to the guys I used their pics.
sneakysnake is offline   Reply With Quote
Old 11-14-2005, 04:19 PM   #3
greenvilledave
well it explains some of it I wonder if i can use a cable from an old q-jet setup from a 71 Thanks
Old 11-14-2005, 10:09 PM   #4
Bob Moore
What year cab do have? Do you currently have a rod or a cable? Using an original set-up would be the easiest.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-15-2005, 12:09 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a FAQ submission by Putter on changing to cable
http://67-72chevytrucks.com/vboard/s...d.php?t=170383
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-15-2005, 11:59 AM   #6
greenvilledave
the cab is a 69 with the rod type fitment. I will try to take a picture tonight i think i am missing a part from the edelbroc carb also oem rod is too short for the eight dave
