How low?
I'm going to order my lowering parts soon and I was wondering how low can you go front and back on 20" rims without C-notching the frame? I would like the 71 Blazer to sit level. I was thinking of on of these two, a 3-5 drop and a 2-4 drop. If you have any pictures that would be a big help too.
Posted via Mobile Device |
Re: How low?
Bump.
I'm interested too. Posted via Mobile Device
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: How low?
http://www.earlyclassic.com/tech.aspx?category=Stance Photos-3
Look for "stance photos. First is stock. Then 2.5/4 Then 3.5/6 Personally I would go 4.5/6.
![]() Join Date: Jun 2004
Re: How low?
So how do you achieve the 3.5/6? Spindles (2 1/2) and - - -
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
Just a nother gear head
Re: How low?
2" spindles and 1.5 springs then 6 " rear springs
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
Re: How low?
ECE parts:
2.5 spindle 1" spring 6" rear spring
Re: How low?
My old 5/6 static drop,...
Proud owner of a 55.1 AD
![]() Join Date: Oct 2006
Re: How low?
I have a CPP 3/5 drop on my '72 2wd Jimmy.
With the top on and the carpet and back seat out it sits a little high in the rear. Once I put the back seat and carpet in it should sit level. However, once I remove the top then it will again not sit level. I had to put a c-notch in because the clearance between the axle tube and frame was too close and would have made contact while driving. At some point I will be replacing the 5" rear springs with 6" springs. Good luck, Bob Posted via Mobile Device |
Re: How low?
Just got off the phone with ECE and they said you can do a 4/6 drop without c-notch. Does that sound right? Wouldn't the axle hit the frame with every little bump?
Next question, what is the easiest c-notch? The porterbuilt bolt in notch looks easy, but you have to take off the body. Thanks, Matt
Re: How low?
You can do a 6" rear drop on a truck without a c-notch.
The blazer would need it. I know that from my own 71 2wd blazer.
Re: How low?
I agree with lolife, my Blazer has a 5/7 drop. 2" spindles, 3" coils in the front, 6" coils and 1" block in the rear. Before I added the 1" block I had to put in a c-notch because it was too close for comfort.
Posted via Mobile Device Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: How low?
I would get the air bag kit from ECE for the rear if you can afford it. This will elimenate all the issuses of ride height differences due to top/seat/payload. Thats what I did, and I liked the ride so well that I put airbags on the front when I did my frame off. Oh, btw, I didnt notch my frame, because I never really had any problem with it before I quit driving it for the restoration process.
#13 |
Re: How low?
5.5"/7" with a cpp bolt in notch
![]() Posted via Mobile Device
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
#14 |
2WD Jimmy
Re: How low?
#15 |
Re: How low?
No need to remove the body for the cpp notch. It bolts from the sides and the bottom. Also the setup is McGaughy's 2.5" spindles and GMC Paul's 3" springs up front. GMC Paul's 5" springs and some 2" blocks out back. I used a McGaughy's adjustable panhard bar in the stock location (PB's panhard will not fit with the CPP notch by the way) and No Limit's shock relocator kit.
#16 |
Re: How low?
What size tires did you have on those 15's? I like the look.
#17 |
Guy with a Blazer
![]() Join Date: Aug 2010
Re: How low?
I have the coils you need , just removed them from my 72 to do air ride , there might be 2000 miles on them in total.
#18 |
![]() Join Date: Nov 2007
Re: How low?
Nice blazer! I was wondering how your blazer drives with that much static drop ? Any issues ?
#19 |
Re: How low?
Can't speak for YBNORMAL but my blazer drives better now than before the drop.
#20 |
Re: How low?
#21 | |
Re: How low?
