07-07-2005, 11:50 PM | #1 |
needin' money
springs and spindles
is the ride from new lowering coil springs really that bad, compared to spindles, is there anything wrong with just runnin lowering springs
SWB Stands for Short Wide Bed |
07-08-2005, 01:50 AM | #2 |
Enormous Member
Lowered springs will make your ride less impressive.
Spindles will lower your ride and give you the same suspension as stock unless you add lowered springs........
"79" Chevy Stepside 350/350 Check my Blog @ www.BaldMikesWorld.blogspot.com |
07-08-2005, 07:53 AM | #3 |
so far, i've just got spindles up front, 3" belltech's.....it rides like a caddy
1987 350 TBI lowered 5/7 |
07-08-2005, 12:10 PM | #4 |
also, spindles keep the stock geometry....get the most drop out of a spindle first, then go with the smallest drop coil.. (ex. 3" drop spindle, 1-2" spring.... not 3-4" drop spring, and 1-2" drop spindle.)
