Old 04-23-2007, 08:53 PM   #1
Ram-Man
Ram-Man's Avatar
Power steering gear box ?'s
I read the faq and did some research on power steering gear boxes. The parts site I looked at shows 67-76 the same part #, 77-79 the same part #, and 80-87 the same part #. Does anyone know the difference from 76-77 change? I assume the 80 on up is the metric threads. What years are you guys using? Will all the years fit the frame the same? I am getting all the parts including hoses and pump so is their and better year gear box to get?
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 04-24-2007, 01:21 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Power steering gear box ?'s
Anyone??
Old 04-24-2007, 01:45 PM   #3
rlm316
rlm316's Avatar
I am doing a crossmember change on a '70 C20 with parts from a '91 3/4t suburban. PS box bolted right to the frame. I am using the '91 front end set-up so it was all replaced with new except the centerlink. All that I could see that was physically different was the arm from the box to the centerlink, and possibly the diameter of the output shaft. The fittings in the top are all the same pipe thread, not sure right now if it is 3/8 or 1/4, but it is the same. Hope that helps. Also someone told me that the newer ps boxes were a turn faster, don't know for sure. Good luck.
rlm316 is offline   Reply With Quote
Old 04-24-2007, 01:57 PM   #4
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Any year up to 87 will bolt right on. You are right about the metric threads. The best to use would be 73-76.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-24-2007, 02:05 PM   #5
rlm316
rlm316's Avatar
The thread pitch on the mounting ears from the '91 was a 7/16 coarse thread. The same thread as the crossmember to frame bolts, and the same as the stock '70 unit.
Old 04-24-2007, 05:37 PM   #6
Ram-Man
Ram-Man's Avatar
Thanks for the help
