07-14-2010, 09:20 PM | #1 |
Cast Iron Headers on a 230?!
I was wondering if any of you have used the cast iron headers available from stoveboltengineco.com I was considering doing the typical tube headers but I want an older look to the motor.
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
07-14-2010, 09:31 PM | #2 |
Re: Cast Iron Headers on a 230?!
I have some on my 65. Work great. No interference with the clutch linkage either. Cast iron and should last forever. Running 2 and 1/4 pipe back to turbo muffs and 2" out the back. Installed by po.
07-15-2010, 01:18 AM | #3 |
X2
I own a pair on my 292 build, not run yet though. Very solid and very cool. Nothing but praise for them when you ask around, like at Inliners.org
292 + TKO500 |
07-15-2010, 10:48 AM | #4 |
I have a set on my 66 250. Love em and they fit perfectly.
07-17-2010, 01:26 PM | #5 |
Six in a row makes it go...
You guys are killing me!
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
07-17-2010, 02:15 PM | #6 |
How about a little peek!!!!
07-17-2010, 05:08 PM | #7 |
07-17-2010, 05:24 PM | #8 |
Yeah! That's what I'm talkin' about! How do they sound?
07-17-2010, 06:38 PM | #9 |
They're very quiet. No ringing like on some headers. I got turbos on it so it's quite quiet. Another pic for you.
07-17-2010, 07:34 PM | #10 |
Geezer, it looks like you took off the heat plate in your second pic. Was there some kind of problem with it?
Ray |
07-17-2010, 07:46 PM | #11 |
The plate was leaking in one corner. Just a drip. Was a bad gasket. It's bolted to the Offy I'm gonna install next week. I'll post some pics of that later when I get it on.
07-17-2010, 07:50 PM | #12 |
Thanks. I was afraid it didn't work, or maybe didn't work satisfactorily.
Ray |
07-17-2010, 08:05 PM | #13 |
It worked excellently. Without it the old 230 stumbles and pharts till it's real warm. Gotta use a bit of choke for awhile!!!
07-18-2010, 12:37 AM | #14 |
Yes, these inlines need heat on the intake manifold. Without it your atomized fuel will puddle on the intake floor and run like crap.
292 + TKO500 |
