![]() Join Date: Oct 2010
Trans and Rear gear
Right now I have a Turbo 400 and 4:56's.
I'm droppin a 350 horse small journal 327 in, I don't want to spin this motor at 7k everywhere I go just to go 60... The truck is gonna be my work truck, it's going to be used, hauling the trailer and racecars, like it did when my grandma owned it. I was thinking, how would a 700r4 with 4:10's do me? I still want this truck to pull anything up the side of a hill, (or close to it) but I would love some drive-ability. |
![]() Join Date: Mar 2010
Re: Trans and Rear gear
It really depends on your rear tire o.d. If your running a 28" tire a 3.73 mated with a 700r trans would be a good all around gear.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner Last edited by gearys 5600; 10-24-2010 at 06:27 PM. |
I'm sure I will meet lots of opposition but I followed the advise of Jake at Jakes performance and went with a 4l80e. I was in the same situation as you and he said that the 700 will work for a while but even built right pulling it in OD will result in a shorter life for the 700. Now I'm sure some of you have put over 1 million miles on your 700 pulling your 5th wheel loaded for bear. Thats all fine and good I went with the advise of someone with far greater experience in the tranny field. Flame away
http://www.jakesperformance.com/Home_Page.html
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot. I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace... 72 short step w/ 388 /4l80e/ and 3.08 gears. |
Active Member
I have to agree with Lowlife.
The 700R4 is not a good choice for pulling. Go with a 3.73 and a T350 or 400 your choice. ( I am a T350 fan) Or go 4.10/4l80E The 1st option will be about 1/3 the money of the second and a fair easier swap.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Isn't the 4L80E electronic?
And a Turbo 350-400 with 3.73's is a no go. Haulin trailer with 3k lbs racecar and a **** load of tools/fuel. 200R4 same as the 700 for the most part, right? |
Hang a Gear vendors overdrive on the back of your 400 turbo, that would be 1 tough combo
http://community.webshots.com/user/hotrodhorn |
Active Member
Yes a 4l80E is electronic but dozens of folks make stand alone electronics for them - hence the added cost.
Why not a T350 or 400 with 3.73 gears? This was a preferred comination from GM engineers for many years The 200R4 and the 700R4 are not the same thing, the 200r4 has next to know aftermarket parts compared to any of the other combinations offered.
#8 | |
Even with the 4:56 rear gear with the OD I think I'd probably be alright, they show you all the ratio's on their site. |
Leave the 4.56 in there and swap in a 4L80 with a manual valve body. This will cost less than the GV, and is better IMO because you will have a lockup converter which won't heat up the transmission oil in OD like the GV will with the TH400. Later, when you get your inheritance, you can replace the valve body and install a controller.
Ray |
Inheritance... lmao! Rub two pennies together is what I'd be told.
Just lookin to make grandma's old truck a stout DD/towing truck. |
#11 | |
