Coordinator of Synchronicity
![]() Join Date: Dec 2005
I am getting the parts together to do a rear brake conv. on a '74 3/4 ton FF 14 bolt 10.5 Corp rearend and will be adding an Eaton Posi as well as new 3.73 gears. All of this is happening on my 1971 3/4 burban.
Now I am having someone else do the Posi and gear change, don't have the experence to not fubar the job...but I want to do the brakes myself. The question is, will I have to pop the diff. cover to release the axles on this rearend or will they release when I unbolt and and remove the large hub units and drums? The answer will help determine which will get done first. |
Re: FF 14 bolt brake conv. question
No need to pull cover to remove axle shafts on floating rearends. All you have to do is unbolt the hubs and pull out the axles.
Hope that helps
Trey Oney |
great... then its brakes first, unless I break the rearend first.
![]() thanks |
Drums don't even have to come off to get the shafts out, just unbolt the 8 axle shaft bolts and the shafts slide right out. Don't even have to jack up the vehicle. The drums are then held on by hub nuts, etc just like front wheel bearings, once you get the shafts out of the way.
Disc conversion is really easy on these axles. I put one under my Jeep YJ and put discs on it.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 05-23-2008 at 01:52 PM. |
So when switching from the drums to the rotors using a '73 3/4 4x4 front rotor, do I still use the inner and outer bearings for said ,73 rotors?
#6 | |
Maybe this will help... http://www.pirate4x4.com/tech/billav...b_disc_brakes/ And you can buy bolt on Caliper brackets all over the place pretty cheap. You don't have to weld them on.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 05-29-2008 at 07:57 PM. |
