Old 04-11-2006, 02:10 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
Header reccomendation
I am thinking of going to hedders, I dont care if they are pretty, I just want them to install easily and sound good. Any reccomendations out there?
thanks
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-11-2006, 04:56 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Re: Header reccomendation
I just put on these a month ago. http://store.summitracing.com/partde...0&autoview=skuThey ain't cheap and they are pretty. Unlike the picture they are shorties not long tubes. Bolt in perfectly. Drivers side exhaust will have a nicer bend if you go to a shift cable and get rid of the linkage. Still looks good even with the linkage. Forget what car they are for but G-man told me wich model to plug in. If you are looking for cheaper you can go to flow-tech long tubes. I bought a set for a little over $100 at Kragens aka www.partsamerica.com. They are listed for our trucks.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 04-11-2006, 05:06 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
flow tech. got mine at auto zone for $85, came with flange and collector bolts and gaskets, and reducers. if you want to spend a little extra time and about $10 to make them look better and not rust. get a can of VHT fire proof header paint, strip the paint that comes with them, and paint with the VHT stuff. looks better and no rust. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
