Old 06-04-2008, 02:08 PM   #1
andresco50
andresco50's Avatar
Aluminium grill ??
Hi my truck is a scottsdale '75 c10 I saw this grill on ebay, but my truck donŽt have the interior hood cable you only can open the hood from the outside... if I install this grill iŽll have problems with the hood opening???
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 06-04-2008, 02:53 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Aluminium grill ??
Yes you will have trouble opening the hood...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-04-2008, 03:17 PM   #3
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
I have that same grille on my '77. It's doable without a cable release, but it's a very tight fit between the second and third bars. I have relatively long thin fingers so it's not to diffucult for me. Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 06-04-2008, 03:19 PM   #4
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I have a grille similar to that on my Suburban. I am able to slide my fingers between it to pop the hood, it's a non-issue for me. It flexes right back.
Judging from the bent slats in that pic, that grille probably has a little give to it, as well...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 06-04-2008, 03:33 PM   #5
andresco50
andresco50's Avatar
Yea maybe it have some space between the bars like this for 24$ + 24$shipping
2001 silverado 2wd
2003 silverado 4wd
Old 06-04-2008, 03:33 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Cut out theopening you need or retrofit an interior hood release set up.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 06-04-2008, 04:53 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
Doesn't the interior release JUST release the hood. Isn't the safety latch still in the grill ? I've never had an inside release on a 70's truck, though when asking about converting to it I was told this is a case. I may have been given bad info though.
Is there someone here who knows for sure and has actually owned a truck with one ? If the safety latch gets moved to the leading edge of the hood on the underside like it should be, then this would be the setup to have.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-04-2008, 05:05 PM   #8
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
got one on my brothers truck, ill go check.
EDIT: ya, there is still a relase behind the grille on his 78. even with an inside release. Could retrofit a mid 80s maybe? anythings possible to the right tools.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-04-2008, 07:22 PM   #9
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Maybe you could make a hooked rod to pull on the release through the grille? Truthfully, opening the hood on mine with a billet grille is no problem.
1977 Big Block Burb
Old 06-04-2008, 08:14 PM   #10
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
I have one on my 79 and I hate it. My fingers are not fat or short but I have a hard time opening it. I also have to push down on the hood to get it to pop and it hurts my fingers because of the weird angle. I’ll be replacing it pretty soon.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 06-04-2008, 08:53 PM   #11
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Stick with the factory one, they can be just as kewl.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-04-2008, 09:06 PM   #12
chevyfan87
...buy hood pins? like 25 bucks at advance auto...not my style but it does the job...
"tell ya what bub"
2000 gmc sierra 1500 4.3 4x4
too poor for the projects
chevyfan87 is offline   Reply With Quote
Old 06-04-2008, 09:40 PM   #13
Pyrotechnic
Thanks for confirming that. I wasn't necessarily interested in running a billet grill, just wanting to keep people honest and make sure the hood can't be popped without access to the inside.
Old 06-04-2008, 10:15 PM   #14
Walts_restoration
The right billet grille looks good. Seeing as my 77 now doesnt have a front clip, a grille is the last of my worrries lol.
Old 06-04-2008, 10:16 PM   #15
andresco50
andresco50's Avatar
I don't know guys the problem is that the original grill is broken and I can find one like that.. is like this one
2001 silverado 2wd
2003 silverado 4wd
Old 06-04-2008, 10:32 PM   #16
Pyrotechnic
Yeah the 75-76 is a little rare. I believe the 78-79 grill is still in production if you like the look.
Old 06-04-2008, 10:42 PM   #17
andresco50
andresco50's Avatar
No I don't like the 77 is too common..... Ok where can I find this grill is not a tube grill check this out!!
2001 silverado 2wd
2003 silverado 4wd
Old 06-05-2008, 11:38 PM   #18
79gmcsierragrande
I’ll send you mine for $50 plus ship. It’ll give me a reason to get one I like.
The grill not the seat.
Old 06-06-2008, 12:37 AM   #19
andresco50
andresco50's Avatar
Thanks man.. but I'm thinking right now there are too many options
2001 silverado 2wd
2003 silverado 4wd
Old 06-06-2008, 12:58 AM   #20
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I have no trouble with mine. It bends the bars to get my hand in there but the y bounce right back. Mine was kinda pricey but very good quality.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-06-2008, 01:34 AM   #21
SmokeShow
SmokeShow's Avatar
Whats available for the 91 model (still square body) front end?
02 Chevy 2500HD D/A EC SB 4x4
MA SCIII trans, EFI Live, 5" exhaust, 5% tint...
83 GMC K30 Crew Cab Short Bed
06 Duramax & ZF6 (to be installed) and more to come...
SmokeShow is offline   Reply With Quote
Old 06-06-2008, 04:46 AM   #22
Pyrotechnic
I believe LMC still makes a no logo reproduction of the 1980 egg crate grill if you want something not seen so much.
