02-09-2012, 04:52 PM | #1 |
67cheby
anyone used ALUMA CLEAR ?
just checked this out, seems to good to be true ? (www.alumaclear.com) $60 for a kit that will do all 4 wheels
02-09-2012, 05:40 PM | #2 |
Re: anyone used ALUMA CLEAR ?
No but I'd like to see if it works. I have some wheels with sandblasted centers that I'd like to keep that sparkly "just blasted" look.
02-09-2012, 05:47 PM | #3 |
67cheby
i called and talked to one of the owners....he swears to never have to polish again !!just sounds to good to be true, he says he can give references from several Semi truck and trailer companies that will vouch for it ? just wanting to know if anyone else has used it or know someone that has
02-09-2012, 09:32 PM | #4 |
I've used a product called "Shark Hide" on my polished aluminum wheels. It's a product that is sold at marine dealers for pontoon boats. It's a wipe on product and not at all like a clear coat that could peel. It seems to soak in to the metal not leaving a "coating" like clear coat does. I've had it on for about 4 years now.....no corrosion and no polishing! It did dull the finish slightly. But that was a great trade!!
02-09-2012, 11:21 PM | #5 |
67cheby
sweet, this guy says it wont dull it either ?
02-11-2012, 05:01 PM | #6 |
67cheby
ttt anyone used it ?
02-11-2012, 05:06 PM | #7 |
I would love to hear some feedback also.
too bad they don't make it for heated apps, I bet it would make the ls1 block and heads look real nice for my swap....hhmmmmm |
02-11-2012, 05:09 PM | #8 |
btw, nice to see a fellow Arkansan, 67cheby!
02-11-2012, 05:15 PM | #9 |
67cheby
Hey yes , just the other side of the state ! i think i am going to buy it and try it first on my trim i am having the anodizing stripped off and dents taken out then polished , and then spray this on , we will see i guess ! Surely someone has tried it , they say they have been in business for 15 years
02-11-2012, 05:43 PM | #10 |
I would imagine it works like powdercoat.A sandblasted intake with clearcoat powder grays real bad!,but a polished intake with clear powder is fantanstic!!!
You are only as good as your oven!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
05-09-2012, 03:30 PM | #11 |
I just used Alumaclear on my Torque Thrust wheels this past weekend and the results were way better than I expected. I have tried several different products including the Mothers Polishing Ball and cleaner but nothing worked very well. My wheels were not corroded at all, just really dull looking. The Alumaclear got them brighter than they have ever been.
It is no more difficult to use than any other product and the results are 10 times better. Don't get me wrong it is still time consuming, but the result is well worth it. I would recommend it to anyone. No harsh smell and I did mine by hand. I can only imagine the result if I would have used the Polishing Ball with it. I really wish I had taken before and after pictures. |
05-09-2012, 03:33 PM | #12 |
Just a follow up. I just used the Polish by itself and it was only $20 versus $60 for the kit.
05-09-2012, 03:52 PM | #13 |
67cheby
take a pic of the after at least and let us see it !
05-09-2012, 04:34 PM | #14 |
I ordered some because I have some billet wheels coming in and I will let you know when I test it. Hope it works cause I love how billet wheels look when they are new!
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
05-09-2012, 04:51 PM | #15 |
I would also be interested in the Aluma Polish. The advertisement says it removes oxidation and brings back the shine. That sure would be nice. I haven't found anything that will remove oxidation.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
05-09-2012, 04:55 PM | #16 |
05-09-2012, 06:12 PM | #17 |
Post a pic if you can... sounds good????
05-09-2012, 08:36 PM | #18 |
I took some pic's but evidently they are too large to download. As soon as I figure it out, I'll get 'em posted for you.
05-09-2012, 08:43 PM | #19 |
I dunno..."easily removed" is in the description. The surface of polished aluminum won't really bond with anything other than oxidation so no matter what goes on it will always need to be re-applied. I think for wheels, there are some good paste waxes out there that cost ALOT less.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
05-09-2012, 09:48 PM | #20 | |
67cheby
Posted via Mobile Device |
05-09-2012, 10:56 PM | #21 |
I have done some "research" on the diffrent aluminum pollishes and found that the cheapest and lowest cost is a DIY that I picked up on the internet. All you need is GREEN joulers paste, mineral spirits, and a good liquid wax. Melt down the green pollish with a electric burnner and a old pan (don't boill), add some mineral spirits to thin out, pour some spirits into aother jug so it won't overflow when you add the pollish, pour the mixture back into the mineral spirits can, add the wax into the mixture (you can skip the wax and put on after as well), shake before and durring use to keep mixed. I have used this for 5 or more years on my alumanum boat, wheels, and fuel tanks and it works very well. If you have somthing that is in need of heavy cutting you can use a diffrent gritt of pollish. Give it a try.
05-10-2012, 08:59 PM | #22 |
OK...I have resized the picture. Let's see if this works. Sorry, I'm not that good at this computin' stuff.
05-10-2012, 09:50 PM | #23 |
Sierra Grande Club
I like the look of that! How lone did it to do the wheels?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
05-11-2012, 07:51 AM | #24 |
It took me about about an hour per wheel doing it by hand. I took the tires and wheels off the truck and put them on my bench. It makes it a lot easier rather than trying to polish them on the truck. Like I said earlier, it is time consuming but not difficult at all. Most of the time you spend on them will be spent doing the nooks and cranny's.
I know some of you are still on the fence about this product, so let me say this. I am 52 years old and I have been doing modifications and restorations since I was about 19. I have seen products come and go and have heard and seen all of the outrageous sales pitches and claims that companies make to get you to buy their product. I fell for some of them and found out that they were just a waste of my money and time. I did not see an advertisment for Alumaclear. I was online looking for SOMETHING that would brighten up my wheels and some how stumbled onto their website. After reading about it for a while I decided, what the hell. Let's give it a try. It either works or or this will be yet another learning experience in not beleiving everything you see. This is the first product I have bought in years that actually works as good as it claims. Now I don't know where some of you guys are coming up with statments like "You will never have to touch them again". When I got mine in the mail and read the directions, this is what I remember: "Once you have applied the product, do not wash the wheel with anything but water for 30 days. After 30 days, coat the wheel with any brand of car wax." I never saw any claims that you never have to touch the wheels again. If you want your wheels to shine, you have to use some elbow grease. It's as simple as that. There is not a product out there that you can simply spray on, walk away and come back and have nice shiney wheels! |
05-11-2012, 01:18 PM | #25 |
67cheby
what the rep told me that i was talking to was that after you polish them with their polish you apply the Aluma Clear that coats the wheels to keep you from having to repolish them !
