Old 12-06-2010, 09:56 AM   #1
NicoSlam
250 to 350 conversion
I just wanted to show the progress I am making in switching my 69SWB from a 250 to a 350. The 250 was original and ran great other then a small flat spot on the monojet between idle and acceleration. I got a good deal on a stock 350 which I have done the following: complete rebuild plus flat top pistons, edelbrock 2102 cam, vortec heads, BS serpenting pullys, SS Headers, Carter AFB 625cfm and all new external components. Also going with an aluminum radiator and dual electric fan setup.
NicoSlam is offline   Reply With Quote
Old 12-06-2010, 10:27 AM   #2
fattyarbuckle
Re: 250 to 350 conversion
sweet looking engine there!
fattyarbuckle is offline   Reply With Quote
Old 12-06-2010, 12:19 PM   #3
Rich916
Rich916's Avatar
No! Another 250 bites the dust...Ill take that power steering set up.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 12-06-2010, 12:45 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Both are great looking engines! let us know as you get closer, I can't wait for a video of that beast running.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-06-2010, 07:24 PM   #5
RCbowtie69
RCbowtie69's Avatar
I love the pulley set up, who makes it, that the set up i need on my motor, what did they cost u, nice set up, looking good, keep on truckin'',
RCbowtie69 is offline   Reply With Quote
Old 12-06-2010, 07:26 PM   #6
NicoSlam
billet specialties produces this as a kit. set you back about $500 but it looks great and everything aligns perfectly.
Old 12-06-2010, 08:13 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice looking update...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-06-2010, 11:45 PM   #8
swamp rat
swamp rat's Avatar
Got a part number for the kit?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-07-2010, 12:19 PM   #9
NicoSlam
Here is the part number directly from billetspecialties: FM2122PC
Old 12-07-2010, 05:52 PM   #10
Ronnny
Nice swap you have thier. Both the motor out and in looks clean. Myself if i could swap my 68 lwb 350/400 for a straight 6 w/3 on the tree in a minute.
Ronnny is offline   Reply With Quote
Old 12-07-2010, 10:57 PM   #11
swamp rat
swamp rat's Avatar
Thanks for the information!! It will definantly be put on my "do" list..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-03-2011, 02:43 PM   #12
NicoSlam
Update: Well it has not gone as smoothly as expected. First off, using the L6 motor mounts, the headers were hitting the clutch linkage. I got a set of v8 mounts which moved the motor forward but now the clutch linkage doesn't align along with the manual crossmember. This was a good enough excuse to justify the cost of a 700R4 conversion. I removed al the manual stuff, changed steering column, and pedal assembly. Added brake booster which required the addition of a neutral safety wiring. I'm waiting for the TV cable and lockup to arrive from bowtie. Once I get the tranny prepped, I should attempt to install next weekend. Then I can get the drive shaft sized and then trailered to the muffler shop.
Old 01-03-2011, 02:53 PM   #13
VDOG
Grand PooBaa Member
VDOG's Avatar
Hang in there, it sounds like you have the right plan. Im curious about the Edelbrock Cam you installed. I bought the same one and installed it in my 283but as I installed the heads, I broke a stud for the roller rockers. Got frustrated, and picked up a 92 LT1 for little of nothing. Anyway, so I never got to use the Edel Cam, and I cant use it in my 92 cause its roller cam.
So once its installed, I want to know how you like the power from the cam, is it a smooth idle, comes in at the right RMP, etc etc. Thanks.
VDOG is offline   Reply With Quote
Old 01-03-2011, 03:00 PM   #14
NicoSlam
Vdog,
I will keep you posted. Its hard seeing the motor on a stand and not being able to run it. I still have not broken in the motor so I'll make sure to take video of the startup and idle. I know words dont come close to pics but there is nothing worth seeing yet. I'll get pics of my tranny teardown when I ge tthe parts in.
Old 01-03-2011, 03:09 PM   #15
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks Nico. I also have a 700R4 that came with the LT1, you mention the driveshaft. Is that something im going to have to address, (driveshaft) when I install mine? First of me hearing this.
Thanks.
Old 01-03-2011, 03:20 PM   #16
NicoSlam
Well I haven't installed the engine/tranny yet but this is what I have gathered. My original setup was an L6/3-speed, therefore the motor was set further away from the radiator. The v8 motor mounts pushed the motor about three inches closer to the radiator. Now from what I gather, a 700R with v8 motor mounts would require one to shorten the DS by 3" but my DS is from a L6 setup so I I think that moving the motor forward and using a L6 DS, I may not need to shorten the DS but I have to wait and see. I may do some measurements tonight and let you know. Being your going with an LT1, it may be different for you. I guess this is the stuff that makes this hobby fun.
Old 01-03-2011, 03:32 PM   #17
VDOG
Grand PooBaa Member
VDOG's Avatar
Sometimes its fun, other times its hell. LOL
My LT1 is in now and runs great, just need a bit more umph.
Heres the link to the install.
http://67-72chevytrucks.com/vboard/s...highlight=vdog
Old 01-03-2011, 04:23 PM   #18
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
may want to look into running mismatch heads.... looks to be one 062 vortec and one 906 vortec?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 01-03-2011, 08:13 PM   #19
Hubscrub
Cruzin
Hubscrub's Avatar
i did the inline 6 to 350 bored 0.60, 700r4 swap a couple years ago..... thinking i miss my 6 with 3speed
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-03-2011, 08:20 PM   #20
swamp rat
swamp rat's Avatar
Wow nice catch!!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-03-2011, 08:23 PM   #21
brans72
I put a 350 in our 67 with 700r4 trans and moved stnds foward (which I got some V8 stands) and driver shaft seeems to fit perfect but yet to start truck.
brans72 is offline   Reply With Quote
Old 01-04-2011, 10:42 AM   #22
NicoSlam
The heads are both 062 (three humps). the single half moon you see on the d-side head is just whats on the opposite end of a 062 head . The 906 has a single hump thats similar.
Old 01-04-2011, 01:14 PM   #23
vasquezmrysvll
"the other guy"
i have the "saw tooth" on both sides of my heads. only way iv ever seen them? also the heads are non-directional.
Old 01-04-2011, 02:58 PM   #24
NicoSlam
I'm not disagreeing with your comment but apparently something alse is going on which may not have anything to do with the heads being 906 or 062. Apparently mine do not have saw tooth marks on both sides of the heads as your do and no literature I have read makes that statement. Maybe I have repos that have both the marks of a saw tooth (062) and the hump of a (906). When I get home, I'll check the casting numbers. That should tell me what I have regardless of shapes etc. I'll post pics this afternoon. Hopefully someone else can chime in.
Old 01-04-2011, 03:10 PM   #25
vasquezmrysvll
"the other guy"
just saying, the saw tooth is more desirable, if your builder advertised "vortecs" you should AT-LEAST get a matching pair, that flow the same numbers. goodluck
